Old 01-30-2014, 07:48 PM   #1
jesse454545
Drives: 2011 CAMARO 2SS/RS
Installing a 160 Thermostat
Is it easy to install this thermostat or would I have to take it to a shop to install it? also is there a DIY on this particular mod that I cant find? Any help is welcomed. Thanks in advance.
jesse454545 is offline   Reply With Quote
Old 01-30-2014, 09:33 PM   #2
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
1. Drain radiator
2. Disconnect lower hose from the thermostat housing
3. Remove bolts from thermostat housing
4. Clean off old gasket material
5. Install new thermostat
6. Reinstall thermostat housing with new gasket
7. Reconnect lower radiator hose
8. Refill radiator and run to operating temp
9. Check for leaks
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 01-30-2014, 09:42 PM   #3
HorsemenLC-SS
Drives: 2010 Camaro SS, 2005 CTS-V
Don't be surprised if your car goes wacko. Mine didn't like the 160. Kept getting alerts not in operating temps. Put the OEM one back no issues. Just tuned the fans to turn on sooner. Same effect.
HorsemenLC-SS is offline   Reply With Quote
Old 01-30-2014, 09:50 PM   #4
EmeryZ28
EmeryZ28's Avatar
Drives: 2011 Camaro 2SS/RS LS3
what do we have stock, 180?
2015 Silverado Z71 6.2/2011 Camaro 2SSRS LS3/2014 Cadillac ATS 2.0T
EmeryZ28 is offline   Reply With Quote
Old 01-30-2014, 09:54 PM   #5
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
The thermostat has a small hole in it that needs to be on the up side. Squeeze the radiator hoses to get air pockets out after refilling with coolant. Make sure you warm the car up in your driveway and let it warm up all the way to make sure everything is working properly before taking it out on the road.
I installed on during the summer and have driven on days as low as 12 degrees without a problem, but I do let the car warm up in my garage to about 150 before hitting the road.
Buttonwillow 2:23.736
Sacramento Raceway 12.89 at 112 mph
Thunderhill 2:22.242
Cuda7050 is offline   Reply With Quote
Old 01-30-2014, 10:17 PM   #6
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Then you did it wrong AND no tuning with the fans to come on sooner is NOT the same thing.
Mine took a few times to burp.
Old 01-31-2014, 07:43 AM   #7
HorsemenLC-SS
With the OEM thermostat stock tune the car would run 205° now with the oem themostat tuned the car runs 180 to 190. The 160 on my V keeps the temp at 180 to 185 as well. I may have had air stuck in there the 2 times I tried going with the 160 but i have had zero issues with the OEM thermostat. Tuned the fans to come on sooner and got the same effect i wanted. The car runs cooler than before.
Old 01-31-2014, 08:53 AM   #8
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
All a 160 thermostat does is make your car take long to come up to temp.
This increases engine wear (all the engine toleranes are off longer).
If you typically make short trips it has the potential to gum up your oil (due to not burning off the contaminates in your pan since you never come up to temp). At best you dramtically reduce your oil life, worst case in needing a new engine from seizing.
It's at best kludge for cooling issues. Do your engine a favor and keep the stock temp thermostat.
BigBlock69RS is offline   Reply With Quote
Old 01-31-2014, 08:55 AM   #9
SNSSTR
All About That Speed
SNSSTR's Avatar
Drives: 2010 Camaro 2SS/RS
Jannetty usually chimes in on these threads. Here's a post he had about it before:
http://www.camaro5.com/forums/showpo...86&postcount=6
2010 SS M6 | 416 CI | H/C/I | GPI TUNED | SNSSTR
SNSSTR is offline   Reply With Quote
Old 01-31-2014, 09:52 AM   #10
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
So?
Does it make it the law around here? No it doesn't.
Old 01-31-2014, 10:14 AM   #11
SNSSTR
SNSSTR's Avatar
So?
I'm not saying it does, I was just offering up one opinion on the issue to someone who probably hasn't heard all there is to hear on it.
Old 01-31-2014, 11:08 AM   #12
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS
I put the 160 in and have no problems. The statement about not coming up to a high enough temperature to burn off the contaminants is bunk. Getting the temp to 160 is plenty high. Its more about the length of time you keep it at temp that's important.
If your engine is stock, keep the stock thermostats. If your supercharging then lower that temperature.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 01-31-2014, 12:04 PM   #13
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
If Ted says it's ok to run or mod it to work better then so be it. Ted has or had 7 of the top 10 fastest camaros on the street. I think he is def worth listening too.
chevy 3 is offline   Reply With Quote
Old 01-31-2014, 12:48 PM   #14
SolomonAKOO
SolomonAKOO's Avatar
Drives: 2011 2SS/RS
So?
Guess it does make it law since Ted said it.
1 7/8" TSP headers straight piped, Custom Tick Performance cam w/ supporting mods, 1" BMR springs and other BMR suspension mods. Tuned with HPtuners by Matt@FSP
SolomonAKOO is offline   Reply With Quote
160, cold, thermostat
