Old 02-01-2014, 03:28 PM   #1
13ZL1BLove
Drives: 2013 Camaro ZL1
ZL1 Wheel Black
So I gashed my right front wheel this summer. I have the black 10 spoke wheels. I want to buy a new one, however, I can only find replica or reproduction wheels. I'm afraid by going with either that the color will be off from the stock rims. Does anyone know if there are factory production wheels? If so where? It's the 20x10 23 offset front passenger wheel.
Thanks, Brandon
2013 Summit White ZL1
13ZL1BLove is offline   Reply With Quote
Old 02-01-2014, 03:34 PM   #2
sabraitis
Drives: 2013 Camaro ZL1 Convertible
Hi Brandon,
I did the same (man that sucks!!). I had my rim refinished and it looks like new. I know my contact is in Canada, but at least you can see their site to get an idea.
http://www.carcone.com/index.html
sabraitis is offline   Reply With Quote
Old 02-01-2014, 04:18 PM   #3
BigBoyBlue
Go NY Giants & NY Rangers
BigBoyBlue's Avatar
Drives: 2013 ZL1 M6
If it's just curb-rash you can go to a wheel place and get it fixed for $100-$300 depending on the damage.
Molon Labe!
BigBoyBlue is offline   Reply With Quote
Old 02-01-2014, 04:23 PM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
the wheel fix it places sometimes have mobile service too. They usually sand the scrape, add filler, and paint it. I have been amazed by their skill in my area.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 02-01-2014, 07:36 PM   #5
13ZL1BLove
We'll I called a wheel repair place and they came out and quoted it at like $350. I dropped the wheel into a car wash thing before I knew the tires were to wide so it's like edge of the spokes all the way around. I found on Phastek Performance a reproduction wheel for $260. Just hesitant because of the finish. Think Ill call Monday and see if it's returnable if it is not the same color or shades off as stock.
Old 02-01-2014, 08:04 PM   #6
SSTG
Drives: 2014 Z51 Corvette
I don't know if you are aware of it or not but they are different than the ZL1/1LE wheels.
If you are wanting to just replace (1) wheel. Some people may notice.
I just wanted to give you a heads up.
http://i805.photobucket.com/albums/y...psd923f60e.jpg
Here is a good comparison of the two side by side.
SSTG is offline   Reply With Quote
Old 02-01-2014, 08:10 PM   #7
13ZL1BLove
Doesn't really look like there is much of a difference to be honest. And I was looking at other wheels, but I really like the stock 10 spoke
Old 02-01-2014, 08:15 PM   #8
SSTG
If your ok with it, that's all that matters.
Old 02-01-2014, 08:32 PM   #9
BigBoyBlue
BigBoyBlue's Avatar
Drives: 2013 ZL1 M6
I'd rather the repaired OEM wheel. I'm sure the replica doesn't weigh the same and has other differences.
Molon Labe!
Old 02-01-2014, 09:19 PM   #10
ZL1-V
I would just repair the wheel, I have damaged two of mine. You buy a new wheel that may not be the exact same wheel and by some bad chance you scratch that one now you have two damaged wheels. Your money anyway, best of luck with it.
ZL1-V is offline   Reply With Quote
Old 02-01-2014, 09:41 PM   #11
13ZL1BLove
Does anyone know the weight of the standard oem black wheel ?
Old 02-01-2014, 09:45 PM   #12
*007
Drives: Getaway Special
These folks are good
http://www.awrswheelrepair.com/index.html
Sip:
*007 is offline   Reply With Quote
Old 02-02-2014, 01:07 AM   #13
hawk02
Coupe Newbie
hawk02's Avatar
Drives: '23 CT5-V BW, '21 Corvette HTC
No clue on the weight, however I can tell you I have a set of Fractory Reproduction rims as part of my winter setup and they are noticeably heavier than the OEM rims.
hawk02 is offline   Reply With Quote
Old 02-02-2014, 06:32 AM   #14
Aussie ZL1
Aussie ZL1's Avatar
Drives: 2013 ZL1 manual RHD
I gave my passenger side rear the gentlest of rubs on a curb last week.
I masked it up and sprayed the area with plasti dip as a temporary fix until I get a wheel guy to look at it.
You'd never know it'd been marked.
I hope this helps
Cheers
Brad Dunstan
RHD '13 M6 ZL1
Aussie ZL1 is offline   Reply With Quote
