Old 02-01-2014, 05:49 PM   #1
Camaro154
Camaro154's Avatar
Drives: 2012 2SS CAMARO IOM
should I be concerned?
I installed pfadt drop springs on my car and got the car aligned to pfadts alignment recommendations. The alignment shop provided me with the alignment adjustment. The tech said I need front camber and caster kit. By looking at the alignment print out should I be worried hiw it is adjusted now? Also do you think I should purchase the front camber and caster kit?
Camaro154 is offline   Reply With Quote
Old 02-01-2014, 06:06 PM   #2
Bo White
Bo White's Avatar
Yeah, its toe'd out in the rear and with that much -camber the inside of the tires will be gone in no time. Also the thrust angle is off because of how the toe on the rear is adjusted. Is the steering wheel straight now? If it is Im very surprised.
Maybe he printed the before and not after? It does say before measurements on the top of the sheet.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 02-01-2014, 06:08 PM   #3
Camaro154
Camaro154's Avatar
It was after the steering wheel is slightly to the left. Hardly noticeable though. Should I buy the suggested kits then?
Old 02-01-2014, 11:21 PM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I can't believe it's that far out. Mine was dead on those settings and had room to go further.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 02-02-2014, 07:57 AM   #5
Bo White
Bo White's Avatar
The only thing I would do is go back and have the rear toe redone to .2 or so and have the thrust angle fixed(which is done while redoing rear toe). Aggressive street specs call for -1* camber front and rear so if that's what you want leave that as is. Front caster is fine as is too.
Totalled:
Old 02-02-2014, 09:09 AM   #6
axis
Search Ninja
axis's Avatar
Which Pfadt settings did you go with. I was assuming you went with the street performance settings.
Halltech CF 102 fed
Old 02-02-2014, 09:12 AM   #7
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
There is no need for a front camber kit on these cars,caster is not adjustable without a cam kit for caster ,which is not needed on your car from his print out.The rear camber is on the low side and may need a larger cam bolt to get more positve camber adjustment due to the droppped springs,Some cars need more adjustment than others.
I would believe this is the before print out though due to the front and rear toe settings if not the steering wheel would be off center.
Bruce@raymondsperformance is offline   Reply With Quote
Old 02-02-2014, 09:16 AM   #8
ssmike
BL1ZZRD
ssmike's Avatar
I dropped mine 1 1/2" and had to get the rear camber bolts to get back to zero, but the fronts were fine! Like Bruce said, no need for the bolts up front!
Old 02-02-2014, 11:19 AM   #9
Camaro154
Camaro154's Avatar
I had then do the regular street settings not the race on the pfadt sheet.
Old 02-02-2014, 11:19 AM   #10
Camaro154
Camaro154's Avatar
What is the the suggested fix then. What exactly should I buy.
Old 02-02-2014, 12:17 PM   #11
Bo White
Bo White's Avatar
Buy nothing. If that printout is were the car sits now then just have the toe redone on the rear.
Totalled:
Old 02-03-2014, 08:59 AM   #12
Camaro154
Camaro154's Avatar
pfadt alignment update
I took it down and had it redone. The tech still recommended I get the kits. Here are the before and new values. I just want to make sure this is done right because I cannot afford to be buying tires all the time.
Old 02-03-2014, 10:29 AM   #13
Bo White
Bo White's Avatar
That will work, total toe front and rear is a touch high but it will do fine. Its probably real touchy on the turn in setup like that.
Totalled:
