Old 02-03-2014, 10:22 AM   #1
omegaman
omegaman's Avatar
Drives: very poorly
Send a message via AIM to omegaman
ZL1 Cabin Airflow
I've notice something unusual about my ZL1's cabin airflow. Fresh air ambient temperature coming into the cabin thru the vent system is significantly warmer than other cars I've owned. I have the heater off (snowflake setting), A/C off, re-circ off, fan speed on 1 or 2.
I am thinking this is because of the aerodynamics of the car - extracting hot air from the engine bay and passing it over the cowl and windshield where it is sucked into the cabin. Have any of you noticed this? What do you all think? (See attached pic of the Z/28 airflow which illustrates this, and aero video.)
2013 Camaro ZL1, Crystal Red, Auto, Exposed Carbon Fiber, Navigation.
omegaman is offline   Reply With Quote
Old 02-03-2014, 10:37 AM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Yeah...heat comes out of the vents even though the fan speed is set on "0". Make sure you have the temp in the cooler range unless you like a toasty cabin.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 02-03-2014, 11:09 AM   #3
revo1059
revo1059's Avatar
Drives: Black 2012 ZL1
Yep, one of my minor gripes. Apparently off doesn't mean completely off.
revo1059 is offline   Reply With Quote
Old 02-03-2014, 02:25 PM   #4
DavidW
Drives: 2013 ZL1 Vert Auto IOM
air is still gonna flow even with the fan off think of the venting as a window, imagine a fan in the window, even if the fan is off air can still pass
the extractor has alot of hot air coming out right infront of the hvac intake, so that is whats getting sucked in
your best bet is to put it on recirc mode and then no air will be moving if the fan is set to 0
DavidW is offline   Reply With Quote
Old 02-03-2014, 02:31 PM   #5
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
all Camaros have done that since the beginning of time
joes407 is offline   Reply With Quote
Old 02-03-2014, 02:32 PM   #6
joes407
joes407's Avatar
my 3rd gen Camaro was the worst ever for that especially after I put headers on it
Old 02-03-2014, 03:20 PM   #7
omegaman
omegaman's Avatar
Drives: very poorly
I don't recall my 2010 5th gen SS having this issue to the same extent as the ZL1. I had headers on the SS, too. I'm wondering if the 2014 SS owners are going to experience this - they also have the extractor hood.
Old 02-03-2014, 06:34 PM   #8
Brownster
Drives: 1966 GTO Convertible/ZL1 Vert
Yea, this has been discussed before.
Do not use the fresh air option without a/c on or you get hot air....
Use recirc.
Brownster is offline   Reply With Quote
Old 02-03-2014, 06:43 PM   #9
Mr. iNCREDIBLE
Mr. iNCREDIBLE's Avatar
Drives: 2012 2SS/RS Convertible
ok you guys know you can really turn of the system so NO air comes thru the vents right?
set the air circ to defrost..
turn fan off then turn fan to 3
press the defrost button and the light will go off
set fan to zero
vents are now closed no outside air will come into the cabin.
I'm 99% on that process, but I will double check when I go home tonight..
this much I do know, the vent/defrost light will not go out if the fan is set on zero, it apparently requires the system powered to actuate and close the blend door.
but if you do it correctly none of the lights on the HVAC will be lit, and the vents will be closed..
I saw a video on this (on this forum) when I first signed up, but for the life of me I can't find it.
*edited and posted video in post #12
I'm only responsible for what I say, not for what you fail to understand.
Mr. iNCREDIBLE is offline   Reply With Quote
Old 02-03-2014, 07:03 PM   #10
hawk02
Coupe Newbie
hawk02's Avatar
Drives: '23 CT5-V BW, '21 Corvette HTC
How I do it is turn the fan all the way off and press the recirculate button. No more warm air through the vents.
hawk02 is offline   Reply With Quote
Old 02-03-2014, 09:31 PM   #11
Drm2Reality
Drives: Possibly a 1LE in the near future.
set the fan to 1
set fan to zero
I am going to try that this weekend! Even with the re-circulating button on this car still pushes heat in. The only major issue I have...since you can feel a slight power loss with AC on.
Drm2Reality is offline   Reply With Quote
Old 02-03-2014, 09:37 PM   #12
Mr. iNCREDIBLE
ok, one correction, which I am going back to edit, the fan has to be turned off then back on to about 3 (1 doesn't do it).. I am going to go make a video of it now since I can't find the other one..
pretty sure the reason for the fan is to have the air pressure close the blend door..
once this is done you won't feel any air coming thru from the outside (so basically like recirc mode) the difference to me is that the system is fully off and closed, with recirc mode the system isn't technically off and I know on cold days my windows just above the defrosters will fog up when only in recirc mode, but they do not do that with this method.
here's the video:
Old 02-03-2014, 09:56 PM   #13
OldScoolCamaro
...my take, the S/C causes sufficient buildup of engine compartment temperatures that gets transfered to the passenger compartment passively. The ride warms up fast, and sometimes depending on the outside ambient temps, no heat is needed at all from the heater control unit inside.
Old 02-04-2014, 02:42 PM   #14
2014CamaroZL1
2014CamaroZL1's Avatar
Drives: 2014 CRT ZL1
I agree that the air flow management sends hot air into the cowl intake.
But more so, that the engine is set so far back into the passenger compartment,
and that the engine produces so much heat.
If the ambient temperature is above 50°, the AC needs to be on.
2014CamaroZL1 is offline   Reply With Quote
