Old 02-03-2014, 12:13 PM   #1
jesse454545
Drives: 2011 CAMARO 2SS/RS
clutch pedal went to shit
So while driving in the freeway yesterday I felt the clutch pedal having a small grinding feeling like medal to medal. It stuck down about 3 times and I had to pull it back up with my feets. Now this morning I go and try to accelerate at a normal rate and boom the clutch pedal falls to the floor and there is no pressure. I pick it up with my hands and it swings back down. I got it towed it to the dealer but I did notice a small amount of fluid on the road when he moved the car. It looked like it was green and it was fresh, what could be wrong with the car? It has a new max corvette clutch and I dont drive it like I stole it.????
jesse454545 is offline   Reply With Quote
Old 02-03-2014, 12:31 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Unfortunately this is a common issue with our camaros - it's due to the clutch reservoir sharing fluid with the brakes. There a couple of fixes. You could install a separate clutch fluid reservoir, or install one of Lingenfelter's "clutch pedal return spring" kits (link below).
http://www.lingenfelter.com/mm5/merc...gory_Code=C366
Click to view my build thread
Old 02-03-2014, 02:39 PM   #3
jesse454545
But it has no return pressure what so ever. The clutch pedal is just falling when I pick it up with my hands
Old 02-03-2014, 02:50 PM   #4
The Stig
The Stig's Avatar
My apologies - I misunderstood your issue.
That sounds like you have a leak in one of the clutch lines.
Old 02-04-2014, 06:54 PM   #5
jesse454545
So the issue was a damaged slave cylinder and $1400 dollars in cost since it doesn't have a stock clutch from GM. The part only cost 200 and labor was 1200. If this happens to you just put it in your garage and do it yourself. Wish I would have done that.SMH
Old 02-04-2014, 07:04 PM   #6
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
My sons 2011SS had the same issue, it was the Clutch Slave Cylinder. It was replaced under warranty along with the clutch which was ruined.
The Bird is the word!
Old 02-05-2014, 08:08 PM   #7
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
Send a message via AIM to blake2010ss Send a message via MSN to blake2010ss
Mine did this...except it was a broken rod on the master cyliner.
2010 Camaro 2SS/RS LS3
1093/1066
416, AGP 6262, E85, Cam
blake2010ss is offline   Reply With Quote
clutch, fluid, pedal, pressure, sticking
