Old 02-04-2014, 07:58 PM   #1
AK47SS
HIDDEN BOOST
AK47SS's Avatar
Drives: 2011 Twin Turbo Camaro
REAR SUB-FRAME BUSHES
Hi does anyone know where i can get 4 x rear sub frame bushes in RUBBER? like the stock ones that come with the 2010 SS? they are the BIG bushes in the rear sub frame. GM only sell them with the complete sub frame?!!
New or 2nd hand will do.
AK47SS
AK47SS is offline   Reply With Quote
Old 02-04-2014, 09:59 PM   #2
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
I just have to ask, why are you needing replacements?
2012LS3VERT is offline   Reply With Quote
Old 02-04-2014, 10:08 PM   #3
Scott@Bjorn3D
Originally Posted by AK47SS View Post
Hi does anyone know where i can get 2 x rear sub frame bushes in RUBBER? like the stock ones that come with the 2010 SS? they are the BIG bushes in the rear sub frame. GM only sell them with the complete sub frame?!!
I have them off a 2013, they are a little more solid than a 2010
Scott@Bjorn3D is offline   Reply With Quote
Old 02-05-2014, 12:14 AM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
+1
The later years or 1LE bushings are better. I DEFINITELY wouldn't put the 2010 OEM ones back in. They provide way too much movement. Why not just get a set of poly ones or if you have $$ to burn, grab the Pfadt solids.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 02-05-2014, 01:31 AM   #5
AK47SS
HIDDEN BOOST
AK47SS's Avatar
I put harder ones in but they are causing too much noise transmission,
AK47SS
Old 02-05-2014, 08:45 AM   #6
td195f
td195f's Avatar
Drives: 2015 Z/28 #786
The GM Performance Parts instruction manual to install the 1LE Performance Package lists the following part numbers for the cradle bushings:
Rear Cradle Bushing, Front - 20941932 (2 req'd)
Rear Cradle Bushing, Rear - 20941933 (2 req'd)
The bushings are better than the stock SS bushing but still rubber.
2015 Z/28 #786 - Black
2004 Silverado 3500 Dually - D'Max - Suncoast - Banks - Edge - Custom Tune by D'Max Tuner / Spitzer '32 Bantam Altered Drag Car - Blown Alcohol 380 CI Small Block Chevy
td195f is offline   Reply With Quote
bushes, rubber, subframe
