Old 02-07-2014, 10:18 AM   #1
Lacpac
Lacpac's Avatar
Drives: 2012 Crystal Red Tintcoat RS
Has anybody tried the new Sta-Bil 360 gas stabilizer?
Realizing it's going to be a longer Winter than expected I'm going to throw some Sta-bil in the tank today. Has anyone tried the new Sta-bil 360? IS it worth $20 a bottle, or just go wioth regular Sta-Bil?
Also, I have a C-Tec battery tender on her but it's connected through the trunk and i'm concerned about having the trunk closed while the C-Tec is on. Don't batteries give off gasses while being charged/tended?
Lacpac is offline   Reply With Quote
Old 02-07-2014, 11:55 AM   #2
BeachBum
Drives: 2012 (ZL-1) #468
I Put "Baby" In The Garage Too For The Winter - She Sets From November 1st Till May 1st - She Too Is On Battery Tender In The Trunk - I Prop The Trunk Open Just In Case Of Gas Build-Up - Fill Her Full Of Gas And Add A Can Of Sea-Foam, Pump The Tires To 40 lbs. And Forget Her Till Spring
BeachBum is offline   Reply With Quote
Old 02-07-2014, 12:15 PM   #3
BLU DUCE
BLU DUCE's Avatar
This is my 4th winter putting car up & have never put a battery tender on it and the garage is not heated. I don't start the car up while in storage & have not had a problem yet with the battery. I always put 1 oz. of Sta-bil good for 20 gals. of gas. Filled up drive home & put up for 6 months. The original battery has an air vent no need to worry about gas build up. That is one reason why you can't just put any battery in this car because of where it is located it has to be a battery with a vent.
Old 02-07-2014, 12:24 PM   #4
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
The battery is vented, so there's no concern. BTW, why not connect the battery tender to the terminals in the engine bay, and close the trunk?
As for Sta-Bil, I have been using the regular stuff for years in cars and small engines. Never a problem. However, the time to put it in is when you fill the tank before storage, not half way through the winter. It needs to get mixed during fill up, and then the treated gas needs to get into the fuel line and injectors when you drive home from the gas station.
Rock-It Man is offline   Reply With Quote
Old 02-07-2014, 12:44 PM   #5
Lacpac
Lacpac's Avatar
Thanks guys, I'll move the tender to under the hood. I'll do one start up to get the stabilizer through the system. Let it run a good 30 minutes. I'll mix it in a gas can before pouring it in the tank. I've got the wheels parked on plywood to get it off the concrete.
Old 02-07-2014, 01:11 PM   #6
BLU DUCE
BLU DUCE's Avatar
Spike III Build
Don't forget to open garage door if you let it run that long. Good Luck
Make sure you use a good extension cord & not very long if you have to.
Old 02-07-2014, 01:12 PM   #7
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
Whether you put additives in the fuel or not, it is highly recommended to top off the fuel tank when you store the vehicle to prevent condisation in the tank.
Dimitrim is offline   Reply With Quote
