Old 02-07-2014, 04:33 PM   #1
Mr. iNCREDIBLE
Mr. iNCREDIBLE's Avatar
Drives: 2012 2SS/RS Convertible
brake pedal wear. (the rubber cover)
2012 Camaro SS with 12,000 miles..
due to the fact that I wear dress shoes to work every day, the brake pedal on my Camaro has worn out already.. (also worn a hole in the carpet from the heel already )
a little disappointing, while other vehicles I have owned have all done this, it usually takes several years and at least 40k-50k miles.
so anyone else have this issue AND what have you used to replace the brake pedal cover? Aluminum? OEM Rubber? Pedal Kit?
I'm only responsible for what I say, not for what you fail to understand.
Mr. iNCREDIBLE is offline   Reply With Quote
Old 02-07-2014, 07:39 PM   #2
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
Personal preference. You could get another OEM pad, or use an after market option. As for the carpet, I hope you meant the floor mat. I can understand the floor mat wear if you only rest the edge of your heel on the floor. I usually have my foot flat. As for the pedal wear, that's a byproduct of your habits. Which are usually the result of sliding your foot up onto, and/or sliding down off of the pedal, as opposed to applying your foot directly onto and pulling your foot off the pedal.
JimE is offline   Reply With Quote
Old 02-07-2014, 10:46 PM   #3
Mr. iNCREDIBLE
yeah floor mat.. . it's the heel of my right foot from being on the gas.
Old 02-08-2014, 01:56 AM   #4
Nzcamaro
NZ Camaro. New Zealand
Nzcamaro's Avatar
Drives: 1968 camaro. 2010 2ss Camaro
You're using the brake too much.
Nzcamaro is offline   Reply With Quote
Old 02-08-2014, 11:25 AM   #5
Mr. iNCREDIBLE
uh huh.. I live in L.A. I drive in stop and go traffic to and from work, sucks but that's life.
and I normally get 60k-70K out of brakes so that's not entirely what it is..
