Old 02-07-2014, 09:09 PM   #1
rray
rray's Avatar
Drives: 2013 GAZ 2SS/RS
DIY: Run A Manual Trunk Latch Cable Around Your Sub Enclosure
Ever wonder how you will open your trunk if the trunk latch motor fails, and you cannot access the child safety latch? The only way I could think of doing
it is to stomp my sub enclosure out of the way.
I have searched for info on the web but have not found any aftermarket cables, but I did find that the convertible camaro has such a cable, because they cannot pull down the seat to access the child safety latch.
So I ordered the cable from GM Parts House, #20995417, and although my trunk lid does not have the same mounting holes, I was able to easily install and route the cable in under an hour after work today. An easy rainy day project that gives me peace of mind.
I slapped together a PDF on how to do it... Please excuse my crappy photos and ignorance at making professional PDF files.
Before I routed the cable to sit behind the seat I routed it outside the trunk and closed it. The trunk lid did not crimp the cable, it just fit fine, then I pulled it to verify it was easy to open the trunk. See the video:
http://youtu.be/UVldrKEH1Uw
File Type: pdf 5th Gen Camaro Trunk Manual Trunk Latch Mod.pdf (1.37 MB, 439 views)
If you see it, get it, for tomorrow it may be gone!
rray is offline   Reply With Quote
Old 02-07-2014, 11:46 PM   #2
SM0KE
IN THE CIRCLE
SM0KE's Avatar
Drives: 2010 IOM 2SS/RS
Not something I feel comfortable trying myself but still a very cool write up. Im impressed
Increasing Circle Size is not important.
Worthiness will knock at the door on it's own accord
SM0KE is offline   Reply With Quote
Old 02-08-2014, 04:28 PM   #3
yzark99
I run 2 catch cans...
yzark99's Avatar
Drives: 2012 1LT SIM Auto
Nice write-up, thank you.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more:
yzark99 is offline   Reply With Quote
Old 02-08-2014, 05:02 PM   #4
redleader
redleader
Drives: 2010
PDF link gone ? :-(
redleader is offline   Reply With Quote
Old 02-08-2014, 05:24 PM   #5
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Great idea! It's the little things like this that make the forum such a good place to learn new tricks to overcome problems we all encounter occasionally.
The Bird is the word!
Old 02-09-2014, 12:01 PM   #6
redleader
redleader
Drives: 2010
I just chopped my handle off at the cable.
I wanted a clear liner for my Artwork.
I back filled and stuck a small piece of the floor liner over the small remaining hole, then pained my Trunk Lid Liner.
Was it a bad thing to do?
To cut it off?
Seemed like it was just loose and inactive unless you really had a need to pull it.
Is that why my Car Alarm is sensitive?
Can't think why....
Old 02-09-2014, 05:30 PM   #7
rray
rray's Avatar
Your's is a good case for running the convertible cable. Both the child safety cable and the convertible back seat cable are connected the same way in the latch motor assembly.
If it's easy to remove your artwork panel, you could open the latch, remove the child safety cable completely, and mount the remote cable. Then run it somewhere else, either on the other side of your sub inclosure, or in your trunk where you can put the "glow in the dark" child safety handle back on, possible on the side of the sub enclosure where it can be reached from both inside the trunk or from behind the seat?
Old 02-10-2014, 02:39 AM   #8
redleader
redleader
Drives: 2010
Cheers rray :-)
Old 02-18-2014, 05:56 PM   #9
BronxxBombers213
BronxxBombers213's Avatar
Drives: 2010 Camaro 2SS RS
just ordered this... cant believe i didnt think of this problem... i have a trunk lid panel and the GMaccessory sub that is bolted in behind the seat, so I would be screwed x2... thank you for the write up!!!!
BronxxBombers213 is offline   Reply With Quote
Old 02-19-2014, 04:02 PM   #10
redleader
redleader
Drives: 2010
This part number is for a 2011 to 2013 Camaro.
Will it work on my 2010?
GMPartsHouse is unsure?
Thx.
Old 02-24-2014, 11:07 PM   #11
rray
rray's Avatar
I would recommend you open your trunk latch sliding door and see if it looks like the one in the pdf to be sure.
Old 02-25-2014, 03:25 PM   #12
BronxxBombers213
Thx.
because there was no convertible in 2010, the part is not listed as such
Old 07-11-2018, 10:13 PM   #13
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
***ALERT*** Old Thread ***ALERT***
Thx for this rray. I'd been wanting to do something like this for quite some time because the roll bar blocks the rear seat when you try to lay it down.
WOW, I did not notice how dirty the quarter panel was until I looked at the picture........now clean.
Also the clips can be removed with a small screwdriver or fingernail
h018871 is offline   Reply With Quote
