Old 02-07-2014, 09:31 PM   #1
Cb34suns
Drives: 2013 SIM Camaro SS
CEL came on after headers install
Just installed BBK shorties on my L99 2 days ago by a professional shop. Which had Solo Performance hi-flow cats and Borla axle back installed previously. Never had CEL....until today. :0( I was under the impression that shorties won't trigger CEL. What went wrong? I checked all connections and checked if everything was bolted thightly...no leaks and all connections appears to be fine. I love the exhaust note and I could definitely feel a boost in power. Car feels lighter at launch.... any suggestions?
Cb34suns is offline   Reply With Quote
Old 02-07-2014, 09:33 PM   #2
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Have you read the code for the CEL? If so, post it up so that you can get better assistance from the knowledgeable folks here at Camaro5.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 02-07-2014, 09:38 PM   #3
Cb34suns
No. But I'm thinking its a cats efficiency code... can't use remote start as well...
Old 02-07-2014, 09:40 PM   #4
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
Remote start wont work when there is a CEL on.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 02-07-2014, 09:42 PM   #5
Batmanntexas
I don't have remote start, but I'm guessing GM put an interlock in place that would disable the remote start feature with a CEL, regardless of the code. Makes sense to me. The only way that you will get it to go away permanently is either get it tuned (offending codes turned off) or put the factory cats back in place. ( I know, NOT AN OPTION )
COTW 9/8/14
Old 02-07-2014, 09:52 PM   #6
Cb34suns
Never had a CEL with just my Hi flow cats on. After installing the BBK shorties that's when I saw the CEL... O2 sensor issue perhaps? Do I take it back to the shop and have them check?
Old 02-08-2014, 12:56 AM   #7
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Did the sensors on the solos get banged around....I have jba shorties with solo hi flows....no cel. Maybe the sensors were hit or damaged during install.
rontammy0 is offline   Reply With Quote
Old 02-08-2014, 03:51 AM   #8
Cb34suns
Could be...taking it back to the shop. Spoke with the manager. Said they'll take care of it....
Old 02-08-2014, 10:14 AM   #9
rontammy0
That's good news..good luck.
Old 02-08-2014, 10:20 AM   #10
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
reset and see if it comes back. i know after installs that a code will throw and reset and never comes back
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 02-08-2014, 11:42 AM   #11
F-16 Camaro
Drives: 2010 Camaro 2SS Black
Keep us updated with what the fix is please!
F-16 Camaro is offline   Reply With Quote
Old 02-08-2014, 11:52 AM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Gotta do it right bud and just tune those rear o2's out. It's just the one way your gonna eliminate your headache.
Old 02-08-2014, 02:45 PM   #13
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Doing it right.....(longtube).
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 02-08-2014, 09:09 PM   #14
rontammy0
Get the shop that installed them to look at it....
