Old 02-08-2014, 01:30 PM   #1
BasedSS
BasedSS's Avatar
Drives: 2014 SS
Help! 2014 stock shift knob removal
They must have changed something in 14 the pull the knob off is not working. Anyone have any intel on this.....PLEASE
BasedSS is offline   Reply With Quote
Old 02-08-2014, 01:57 PM   #2
Grizley
Grizley's Avatar
Drives: 2010 2ss rs
If it's the same as the 2013 then there is a screw on the right side of the shifter just under the trim ring under the boot. You have to pull the boot up as far as it will go in order to see it.
Grizley is offline   Reply With Quote
Old 02-08-2014, 04:10 PM   #3
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
^Actually, you have to first rotate the chrome collar at the bottom of the knob in a counterclockwise and downward motion. That will grant you access to the screw as well as let you remove the knob from the boot/collar.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
Old 02-08-2014, 09:38 PM   #4
MonsterV6
MonsterV6's Avatar
Drives: Chevrolet Camaro
Correct, but my was so hard to do that I gave up and broke the crime ring around it, I didn't care I was installing a Hurst shifter.
MonsterV6 is offline   Reply With Quote
Old 02-08-2014, 09:42 PM   #5
BasedSS
BasedSS's Avatar
Drives: 2014 SS
Exact same thing I did hahahahaha.
Old 02-08-2014, 09:57 PM   #6
Airmaster
Go Gators!
Airmaster's Avatar
Drives: Camaro Jeep Abarth 944 325i
Like others are saying (if it's like the 2013 which I believe it is)...
You have to gently lift up the chrome collar, turn about 1/4 turn counterclockwise, pull the boot down, use a torx bit to unscrew the securing bolt, than finally lift that puppy off. While it's off do yourself a favor and put a short throw shifter in there if you aren't already!
'13 Camaro, '97 Wrangler, '12 500 Abarth, '85.5 944, '06 325i
Suspension Mods: BMR and JPSS Sways, BMR Poly Bushings, BMR strut tower brace, BMR control arms, BMR toe arms, stock springs and struts
Engine Mods: All bolt ons (haha)
Brake Mods: Brembo SS caliper swap front and rear
Airmaster is offline   Reply With Quote
Old 02-08-2014, 10:02 PM   #7
Grizley
Grizley's Avatar
Drives: 2010 2ss rs
lol, by the time i got to that point on mine the shifter was broken and just lifted off without needing to rotate the trim ring.
Tried pulling....and pulling....and pulling per instructions...at times sounding like a squealing pig.....then heard a pop and off it came.....leaving a portion still attached to the shaft
I should have checked the forum first but being the man that I am said "I got this, how hard can it be"
Lesson learned
Old 02-10-2014, 12:56 PM   #8
NotSS1LEnt
Drives: 2014 2SS/RS 1LE Bright Yellow
Send a message via Yahoo to NotSS1LEnt
This being my 3rd 5th gen I decided that I knew what I was doing......No chrome ring for me either
NotSS1LEnt is offline   Reply With Quote
Old 02-10-2014, 01:30 PM   #9
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Sounds like if you know how to remove it that it's easier than the 2010's was to remove. I almost knocked myself out when I removed it.
9/26/09 Took delivery!
Old 02-10-2014, 03:56 PM   #10
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
I actually posted a DIY on this for 2013 and up last spring... Sorry for your troubles.
chef-beavis is offline   Reply With Quote
Old 02-10-2014, 04:50 PM   #11
kansjfr
Drives: 2013 2SS 1LE
Yep, your post saved me from destroying the shift boot when I put my EPCO knob on my shifter. Many thanks for posting it.
kansjfr is offline   Reply With Quote
Old 02-10-2014, 09:22 PM   #12
chef-beavis
You're welcome. I ruined mine but didn't need it. I also yanked on mine like crazy because I had a 2010 before. The new setup is easier once you know about it!
Old 04-10-2014, 12:56 PM   #13
Chris14RS
Chris14RS's Avatar
Drives: RRM RS v6
I have a 14 RS and the trans. shop had no idea how to remove the stock knob. Great shop...new cars can be a pain in the butt. I talked him through it from this forum! Great info on here!!!
Chris14RS is offline   Reply With Quote
Old 04-10-2014, 01:10 PM   #14
Visago
Visago's Avatar
Drives: 2010 Camaro 2SS/RS
LOL! Gotta be real careful when you're pullin on the shaft.
Visago is offline   Reply With Quote
