Old 02-11-2014, 09:42 PM   #1
Barbarino
Drives: 2013 camaro ss
What gauges would you recommend?
I'm looking for some gauges for my 2013 ss and I'm not sure what gauges are the best for the money.. Thank you.:
Barbarino is offline   Reply With Quote
Old 02-11-2014, 09:49 PM   #2
jvoisel
Drives: 2010 2SS/RS M6
ADM AFR/BOOST gauges that mount on the cluster look good.. Not sure what you need gauges for; Aeroforce Interceptor gauges read multiple things and can read/clear codes. Only ones I would consider for my car.
2010 2SS/RS
jvoisel is offline   Reply With Quote
Old 02-11-2014, 10:05 PM   #3
Barbarino
I want a wideband and fuel pressure and boost, I have a vortech From JRE and I would like to be able to monitor what is going on.
Old 02-12-2014, 01:52 AM   #4
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I have a little bit of everything going on....
aeroforces read boost (through OBD port), kpa, oil pressure, oil temp, ambient temp, intake air temp, rpm (serves as shift light). Also reads and clears DTCs. There are a TON of parameters they can monitor and record.
eboost2 reads boost from manifold log (added when turbos were installed)
PLX reads AFR and fuel pressure.
It seems very busy but it saves me from having to scroll through the interceptors so much once I started to remember what gauge was showing what.
Old 02-12-2014, 09:10 AM   #5
Barbarino
That looks awesome blake-b!! I've been looking at the cobalt gauges or the aem gauges, I've looked and I can't find any bad info about either one.
