Old 02-15-2014, 11:25 PM   #1
tegwin
Drives: 01 V6 camaro
car idles like it has a cam??
Hey there, I had the typical (water elbow) water issue on my 3.8 V6. so I replaced them with aluminum ones, it was not as big of a PITA as people make it seem.
I did the "Free ram air mod" to the air box, and when I started the car, it idled like it had a lopey cam in the motor, to the point where on the brakes it would move the car forward a tiny bit every time it revved up haha
so, would the "ram air mod" make this big of a change???
Also, llifter tap/tick, at all rpm's with high oil pressure, bad lifters?? needs a motor?? it has 149,801 miles. or just something that's easy to fix with detergent, and new oil??
tegwin is offline   Reply With Quote
Old 02-16-2014, 05:40 PM   #2
tegwin
no vacuum leaks, unless it's a intake manifold gasket, and I didn't touch them, no whistling noises, or sucking sounds, or any of the few other vacuum leak noises
Old 04-28-2014, 03:23 AM   #3
enzia35
Drives: '16 Garnet Red 1SS
Last time mine did that it was the MAF. 01V6 Camaro too, haha.
'16 Camaro 1SS
'18 Miata GT
Gone: '01 Camaro, '14 Camaro, '90 Miata
enzia35 is offline   Reply With Quote
Old 05-08-2014, 04:15 PM   #4
Lee0123567
Nope! v6.
Lee0123567's Avatar
Drives: 2001 SOM v6
Yep, probably the mass air flow. Mine did the exact same thing after i did that mod
3" Magnaflow cat-back, MSD 8.5mm Super Conductor Wires, NGK Iridium plugs, KN Air Filter, Halo Headlights, Shaved Air Lid, Chrome ZR1 Rims, SS Hood Scoop/Spoiler
Lee0123567 is offline   Reply With Quote
Old 06-02-2014, 06:14 AM   #5
tegwin
Mine doesn't do it anymore, well sometimes it will randomly. but not very often lol usually at car meets, and when someone is around, so it'll sound awesome
