Old 02-18-2014, 05:12 PM   #1
camaropop
Drives: 2010 Camaro ss eforce
rx catch can question
I noticed that the hose coming from the eforce to the can was sucked flat when the car is running is this supposed to happen? I have it hooked up correct wondering if the pcv valve is bad. Any help would be great. Thanks
camaropop is offline   Reply With Quote
Old 02-19-2014, 05:31 PM   #2
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Nope - you should check to see if the PCV check valve is working right. It should be one way. I have it hooked up to my Eforce and mine does not do that.
-Mark.
Old 02-19-2014, 10:52 PM   #3
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
If the check valve is bad, good look getting ANY support from RX.
-John S.
Old 02-19-2014, 10:57 PM   #4
B-_-RAD
Banned
Drives: ...
Why is that? They are helping me with mine no questions asked.
B-_-RAD is offline   Reply With Quote
Old 02-19-2014, 11:08 PM   #5
grocerygetter
instigator
You can search here if it hasn't been deleted.
-John S.
Old 02-19-2014, 11:21 PM   #6
B-_-RAD
Banned
Drives: ...
I'm not all that concerned, however I do not agree with people posting false statements, RX has gone above and beyond to help me. What has happened with them in the past must no longer be the case as they were more than happy to go out of their way to help with my situation.
Old 02-20-2014, 04:37 PM   #7
pdiddy
Drives: 2011 2SS
So I am not 100 percent sure with the E Force but I b elieve with roots type blowers you dont need the check valve I broke mine so I was looking to get a new valve and called Ted Jannety and RX both and they said with my Maggie the check valve is not required so I just put a normal 90 fitting on there and thats it. (it has to do with the way the pressure works on roots blowers I believe there is some smart guys on here that could explain better and I would love for them to just to give me a good underdstanding
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
pdiddy is offline   Reply With Quote
Old 02-22-2014, 01:44 PM   #8
Stingr69
'69 Owned Since '79
Stingr69's Avatar
You can just run a 1/4" pipe thread fitting in place of the PCV/Check valve. It would just screw right in to the existing threads.
