Old 02-22-2014, 11:14 PM   #1
TigerFA
Drives: Camaro 2SS 2017 Red Hot
1 to 4 Shift
Just wondering what that 1 to 4 shift is all about, the manual doesnīt tell you much what it is really for. It happened to me 2 times today, it just says when the fluids are to cold or something but the car and transmission was warm when it happened. Does somebody can explain what this gimmick is for?
Greetz Steve
TigerFA is offline   Reply With Quote
Old 02-22-2014, 11:16 PM   #2
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
It's called skip shift. It's in every GM vehicle with a manual trans for as long as I can remember. A while. I believe it helps fuel economy. A cheap skip shift eliminator will fix that for you. I don't really notice it on my 1LE.
Old 02-22-2014, 11:18 PM   #3
F-16 Camaro
Drives: 2010 Camaro 2SS Black
Skip Shift as it's referred to happens when your speed and RPMs are in a specific range(low, don't have exact numbers)
The purpose is to "improve" gas mileage. This car has enough power that going from 1-4 is possible. I personally don't see how it improves gas mileage.
You can get rid of it a few ways:
1) Speed up then shift
2) Buy a skip shift eliminator
3) Tune it out
4) Some people report hitting the reset button on the left tab thing(the menu/DIC controller)
F-16 Camaro is offline   Reply With Quote
Old 02-22-2014, 11:20 PM   #4
TigerFA
have also the short throw shifter installed from factory, is it normal it does that? the other thing the tank was lower than 1/4, maybe it will help for economy to not burn out the tank so fast?
Old 02-22-2014, 11:32 PM   #5
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Greetz Steve
Here see this post it explains it in detail and how to eliminate it with a $25 10min fix... first mod I made when car was 3 days old. Now when i see the 1-4shift display I tell it to go f**K
yourself !
http://www.camaro5.com/forums/showth...highlight=skip
camguynj is offline   Reply With Quote
Old 02-22-2014, 11:40 PM   #6
TigerFA
yourself !
that's what I think, didnīt got this car for economy if I want to go from first in second just let me do it that's why I got a MANUAL! Darn... will see... thanks guys for the info
Old 02-23-2014, 12:23 AM   #7
mikeyg36
Drives: 2015 Z/28 #533
I was so happy when mine was tuned out. It would always come on at the worst times, and I'd end up fighting with since I refused to let the clutch out and listen to the drone/vibration/engine lug that it caused.
mikeyg36 is offline   Reply With Quote
Old 02-23-2014, 08:29 AM   #8
2011ss/rs
2011ss/rs's Avatar
Drives: 11 ss/rs RJT w/Black Cherry stripes
Send a message via AIM to 2011ss/rs
Mine is tuned out but if you shift it above 17 mph it will not throw you into 4th gear.
2011ss/rs is offline   Reply With Quote
Old 02-23-2014, 09:14 AM   #9
BlaqWhole
Drives: 2017 Camaro ZL1 A10
It was done to help them keep the MPGs within a certain range to avoid the gas guzzler tax. The cost of owning one of these cars would be a lot higher if we had to pay extra for it being a gas guzzler. And even tho you didn't buy the SS for the fuel economy, they still have to keep it somewhat comparable to the Mustang GT and the Challenger RT/SRT-8. Could you imaging if they were reporting 21 MPGs while we were only getting let's say 14 or 15 MPGs? So while these features (skip-shift, displacement on demand) are annoying, they do serve an important purpose. And at least there is a way for a person to by-pass them if you so desired.
BlaqWhole is offline   Reply With Quote
Old 02-23-2014, 10:35 AM   #10
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
In reality it doesn't do much to help fuel economy, but it scores points with the EPA and helps GM avoid having to charge us a $2000 Gas Guzzler Tax. It sucks but I'll take a $25 solution to a $2000 problem any time.
Old 02-23-2014, 11:39 PM   #11
Pitboss
Pitboss's Avatar
Drives: 2013 AGM 1SS
Pitboss is offline   Reply With Quote
Old 02-24-2014, 12:12 AM   #12
FB3
FB3's Avatar
Drives: 2014 Camaro 2SS RS LS3, BRM, NPP
Yea, hooray for the nanny EPA - Trying to put US companies out of business every day.
Experience is the best teacher but the tuition is very high.
FB3 is offline   Reply With Quote
Old 03-08-2014, 04:46 PM   #13
glider65
Drives: 2011 Camaro 2SS Convertible
Found this piece about it...
This message will come on when:
The engine coolant temperature
is higher than 76°C (169°F),
The vehicle is going 24 to
31 km/h (15 to 19 mph) and
The vehicle is at 21 percent
throttle or less.
glider65 is offline   Reply With Quote
Old 03-08-2014, 09:11 PM   #14
TeelsBlack
TeelsBlack's Avatar
Drives: 2013 Black-on-Black 2SS/RS
I just installed the skip shift eliminator yesterday. Cheap & easy fix. Makes driving much more pleasant without the computer telling me how to drive.
TeelsBlack is offline   Reply With Quote
