![]() Drives: 2012 Camaro LS Join Date: Feb 2014
My camaro is overheating and the heater is blowing out cold air!!
![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro 2LT RS Join Date: Mar 2012
Engine Coolant Thermostat Housing Removal
![]() Zoom and Print Options ![]() 1. Remove the heater inlet/outlet pipe assembly bolts. 2. Remove the heater inlet/outlet pipe assembly. ![]() Zoom and Print Options ![]() 3. Remove and discard the heater inlet/outlet pipe assembly O-ring and gasket. ![]() Zoom and Print Options ![]() 4. Remove the thermostat housing assembly bolts. 5. Remove the thermostat housing assembly. ![]() Zoom and Print Options ![]() 6. Remove and discard the thermostat housing assembly O-ring and gasket. |
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
Thanks for your post and I apologize for your overheating concerns. Have you contacted your local dealer to schedule an official diagnosis? You may also feel free to PM me your VIN so I may check my resources for any known issues. Kind regards, William R. Chevrolet Customer Care |
etmx183,
ohh So its behind the engine! Thank you all the diagrams i was looking at was showing that it was in the front. i guess they are not in the same place as the v8 |
#5 | |
376 cubic inches of fun
This has happened to me on some other cars that don't have a visible surge tank. |
#6 |
![]() ![]() ![]() ![]() Drives: 2012 2LT/RS Join Date: Oct 2011
I was losing coolant too, since the car was new. Many years later found the source, since it was getting worse you couldn't miss it. It's that pipe at the top front of the engine that the coolant hose connects to. You will have to remove it and replace the o-ring where it mounts. I found it easier to just order a new one, it's not called what you would think it would be called
![]() https://www.rockauto.com/en/moreinfo...pt=10337&jsn=8 |
| Tags |
| thermostat |
