![]() Drives: 2013 White camaro 1LT/RS Join Date: Feb 2014
Help with grill lighting. engine bay fuse box
hey everyone, I need help! installing grill lights from Phastek with the remote so I would just like to run the power from somewhere in the engine bay, not from inside.
I was thinking I can tap into the fuse box in the engine bay with the Add-a-cuircut plug...just like you would with the fuse box inside. my question is, can I do that? what one would i need to tap into to have constant power running? or is there any other way to get constant power to the grill lights from within the engine bay? ![]() pics would help, I'm only 18 and not really good with wires, but I'm learning as I do mods! |
INFECTED
Drives: 2011 1LT Synergy Green Join Date: May 2011
You can do the add a fuse like your talking about , or when you lift the fuse box cover there is a constant hot right in front Big red hot lead , I just used that and put a disconnect plug on it for my grill led lights and strobes in the engine bay . I used a batty tender quick connect and just plug in for shows and keep it unplug when not in use . Also on the other side is your Battery post that is always hot , LOL I also did another set up on this side to power six tubes of leds in the engine bay same set up ..hope this helps .
#3 | |
| Tags |
| grille lighting, light upgrade, lighting modifications, wire |
