Old 02-25-2014, 07:23 PM   #1
angie7
Smoked by a GIRL
angie7's Avatar
Drives: 2014 2SS/RS
Header install tips?
A good friend, my fiance and I will be installing my headers on Friday. He's done this many times as he builds race cars but only Mustangs. This will be his first Camaro header install. Any special tips or secrets before we start? Unfortunately we will not be using a lift which is going to make it harder but we will make it work.
Also we are installing a 160* thermostat, any special tips on that. I assume its fairly cut and dry but never hurts to ask.
Thanks!!!
PS. Headers are TSP 1 7/8 w NO cats
2014 2SS/RS Summit White w/ IOM interior "Powder 2.0"
angie7 is offline   Reply With Quote
Old 02-25-2014, 07:26 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
If he has done headers before he will have no problem doing it on a Camaro. The higher you can get the car the easier it will be. Be sure to remove all the spark plugs so you don't accidentally break one and freak yourself out when you start it up. Have fun!
Old 02-25-2014, 07:30 PM   #3
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
I did mine in my garage. All I can recommend is just get it up as high as you can. It was by far the easiest header install I have ever done. Taking my time it only took me about 4 hours.
newagemuscle is offline   Reply With Quote
Old 02-25-2014, 07:33 PM   #4
angie7
Smoked by a GIRL
angie7's Avatar
Drives: 2014 2SS/RS
He said it looks very easy to do. He's been watching YouTube videos on it, lol. But I'm a worried mama
Old 02-25-2014, 07:49 PM   #5
Chevy Fanatic
Drives: 2011 2SS/RS IOM/PEARL STRIPES-6M
Thanks!!!
I recommend getting the stock exhaust hot and then cracking the 02 sensors loose, this will help reduce the chance of galling the sensor threads. I have removed hundreds of 02 sensors this way without ever damaging the sensor threads. Removing the sensors on a cold exhaust generally results in stripped sensor threads, requiring replacements.
Whipple S/C, 3.750 pulley, JRE rough idle blower cam kit, Trunion upgrade, C5R timing chain, LS2 chain dampner, Melling 10296, Dynatech 1 7/8 LT headers, OR pipes, Dual valve RX catch can, ID 850 Injectors, LPE Dual fuel pump, CAI with Apex scoop, VMax ported T/B, ADM Tune 675 RWHP 560 TQ
Chevy Fanatic is offline   Reply With Quote
Old 02-25-2014, 07:55 PM   #6
angie7
Smoked by a GIRL
angie7's Avatar
Drives: 2014 2SS/RS
Heat them with a gun or just general driving? Its a half hour there so everything will be hot from driving.
Old 02-25-2014, 08:04 PM   #7
Chevy Fanatic
The drive will be sufficient, as long as you don't let the exhaust cool off too much before you start your work.
Old 02-25-2014, 08:07 PM   #8
angie7
Smoked by a GIRL
angie7's Avatar
Drives: 2014 2SS/RS
Ok great thanks!
Old 02-25-2014, 08:16 PM   #9
Indydriver
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH
No cats?! You must like it loud and proud!
Indydriver is offline   Reply With Quote
Old 02-25-2014, 08:28 PM   #10
angie7
Smoked by a GIRL
angie7's Avatar
Drives: 2014 2SS/RS
Sure do lmao!! Its not a daily driver so I doubt it will bother me too much. Ive always been a louder the better kinda girl. I have Flowmasters on it now and no where close to loud enough.
Has anyone heard of the oil dipstick not fitting in the tube after installing headers? Friend of mine installed the same TSP I'm installing and said his wouldn't fit.
Old 02-25-2014, 08:32 PM   #11
revived
Vrrrm.
revived's Avatar
Drives: 2011 2SS/RS LS3
It fits fine no issues with tsp.
revived is offline   Reply With Quote
Old 02-25-2014, 08:41 PM   #12
revived
Vrrrm.
revived's Avatar
Also you shouldnt need to heat o2 to get the loose, adjustable wrench and a hit with hammer loosens it and can spin them off by hand dont know why they say to heat them thats dumb you can burn youself.
Old 02-25-2014, 08:54 PM   #13
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
if you have a hard time putting back the dipstick go under the car and put your hand on the block more or less where it goes till you find the hole have someone put it in from the top and you guide it in on the bottome quick and painless
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 02-25-2014, 09:06 PM   #14
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
There is a good post in that DIY section that should be all you will need.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
