Old 02-26-2014, 08:21 AM   #1
headgamez
Drives: 2018 Camaro ZL1
Rim size
Hey guys,
I am thinking about running a raked setup, with 245/45-20 up front, and a 315/35-20 out back. Can anyone forsee any problems with this setup?? I will not be roadcoursing or anything, just would like to know if this may cause some handling issues.......
TIA,
HG
headgamez is offline   Reply With Quote
Old 02-26-2014, 11:16 AM   #2
Jenner
Jenner's Avatar
Drives: 2012 SS/RS
If you're not racing or anything I don't think a 315 is necessary. Personally I would go with a 295 or 305 just to save a few $$. If you don't mind spending a little more for a wider tire then go for it. Just make sure your wheel is wide enough for a 315.
Jenner is offline   Reply With Quote
Old 02-26-2014, 11:40 AM   #3
headgamez
Thanks a lot! I will be doing a little drag racing, therefore I thought that the factory 245 up front would be okay.
Old 02-26-2014, 12:40 PM   #4
Jenner
Jenner's Avatar
Drives: 2012 SS/RS
Old 02-26-2014, 09:07 PM   #5
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
That combo will work fine for driving around and straight-line stuff. Out on a road course, however, the narrow front tires will educate you quickly about understeer and mowing grass.
Tony
Fquick.com/NineBall
Old 02-27-2014, 02:43 PM   #6
headgamez
Tony
Thanks Tony!! The car is a DD, and I love the aggressive raked look. I tend to also do a lot of highway driving, so I hope that the 245 will be fine.
Old 02-27-2014, 03:16 PM   #7
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
I run Nitto Invos 275/ 40/ 20 on 9" rims front and 315/35/20 on 10" rears, 35 offset on TSW Nurburgs. Should be a 10.5" rim on back, but works great. This combo better for handling then 245 front, and the tire diameter still same front/back as stock
VR Baron is offline   Reply With Quote
Old 02-27-2014, 04:59 PM   #8
RaiderSS
RaiderSS's Avatar
Drives: 2010 Camaro SS2 DeadBLK
Agreed this car responds well to 275/315 daily driving or road coarse but i run a 9" rim up front and a 11" outback...
RaiderSS is offline   Reply With Quote
