Old 02-26-2014, 11:07 PM   #1
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
32mm Adjustable Rear Sway Bar
Pete at Pedders recommended upgrading the rear sway bar on the 1LE to the ZL1 spec 32mm adjustable bar. I would like to get reviews from anyone that's added a stiffer rear sway bar on how well it worked at autocrosses and HPDE's? What hole setting seemed to work best for you? Did you experience too much oversteer?
Thanks for the reviews.
Buttonwillow 2:23.736
Sacramento Raceway 12.89 at 112 mph
Thunderhill 2:22.242
Cuda7050 is offline   Reply With Quote
Old 02-27-2014, 08:09 AM   #2
SVThis
SVThis's Avatar
Drives: 2013 1LE 1SS Victory Red 1 of 76
I wouldn't mind knowing the answer to that myself
2013 1SS 1LE Victory Red. 187 CAM-C
SVThis is offline   Reply With Quote
Old 02-27-2014, 04:45 PM   #3
Arubberbaby
141LE
Arubberbaby's Avatar
Drives: 14 AGM 1LE
Well I just ordered BMR's new 32mm bar for the rear today along with some bushings. I'll try and get info back to you guys asap. I'm trying to follow pete's advice on the 1LE handling without the availability of Pedders parts.
Arubberbaby is offline   Reply With Quote
Old 03-01-2014, 09:44 AM   #4
EarlyApex
Drives: 2013 IOM 2SS 1LE
I am installing BMR's 32 mm bar this weekend. I found a set of Pedders radius arm bushings on Amazon and got a set of Whiteline cradle bushings on the way. I hope to get the alignment done next week so I might have feedback soon.
I plan on setting the bar up on the middle setting at first until I have a chance to test it out.
EarlyApex is offline   Reply With Quote
Old 05-10-2014, 08:15 PM   #5
L99CAMA2011
L99CAMA2011's Avatar
I had Pedders ZL-1 bars and just sold my Pfadt ZL-1 bars and bought the BMR new bars. Of all 3 I love the balance of the BMR bars the best but the Pedders rear 32mm FE4 bar is the stiffest.
