View Poll Results: Stored 6 months with no tender will it start?
Yes 40 72.73%
No 15 27.27%
Voters: 55. You may not vote on this poll
Old 02-27-2014, 11:16 AM   #1
Mannsiam
Mannsiam's Avatar
Drives: 2014 Camaro 1SS/RS 1LE
Storage Experiment
Ok so I have a 2014 1LE with 770 miles on it. It went into storage in my garage on 10/21/2013. The only time i even opened the door was for a 15 minute quick install of a shifter knob other than that it sits under a cover. I am not unhooking the battery, putting a tinder on it, or starting it. I plan on replacing the exhaust in mid April, that is when I will start it for the first time. Will it start or do you think it will be dead?
Yeah Im a Chevy Guy. 11 Silverado, 12 Malibu, 14 Camaro 1LE
Mannsiam is offline   Reply With Quote
Old 02-27-2014, 11:18 AM   #2
renyart
renyart's Avatar
Drives: 2013 ZL1 Convertible
DEAD!
renyart is offline   Reply With Quote
Old 02-27-2014, 11:21 AM   #3
2SS 2011
2SS 2011's Avatar
Drives: 2011 Camaro 2SS/RS M6 Black
You never know.. It might start right up.. Just think about how many cars are on a dealer lot that sit and don't get started for months.. Some need a jump some don't.. It depends..
2SS 2011 is offline   Reply With Quote
Old 02-27-2014, 11:28 AM   #4
BowtieBelle
They see me trollin'...
BowtieBelle's Avatar
Drives: 217 ci of fury; Chauffeured by SS
I think it'll crank right up but I could be wrong, I had a friend store his ZL1 for 2 months and it wouldn't start!
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread
BowtieBelle is offline   Reply With Quote
Old 02-27-2014, 11:30 AM   #5
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
Mine sat for 6 months last winter, no tender, etc. No problem. Fired up like it was stored the day before. My garage isn't climate-controlled, either.
Bye bye, Bumblebee!
Old 02-27-2014, 11:37 AM   #6
Dfault
Dfault's Avatar
Drives: 2014 Camaro SS
Not all batteries are the same, you could be lucky and it start right up or you could be unlucky and have to get it recharged. Either way it goes, good luck!
Dfault is offline   Reply With Quote
Old 02-27-2014, 11:42 AM   #7
K1SSRSS
Chief Many Camaros
K1SSRSS's Avatar
Drives: A paid off Camaro!!!
It will start no doubt, I have left ours parked multiple times for months on end and never had a problem. I just hope you put stabil in the gas tank. Gas will start to go bad in your time frame of 6 months or so, the car will still run it just won't be as happy.
504hp/478tq
Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake
Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods
Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac
K1SSRSS is offline   Reply With Quote
Old 02-27-2014, 11:46 AM   #8
Mannsiam
Mannsiam's Avatar
Full tank and stabil. I also have it on dollys so I can move it around the garage if need be.
Old 02-27-2014, 11:58 AM   #9
HDRDTD
For me, the small price of a tender lets me sleep better knowing it'll start after sitting for a few months.
Will it start without a tender? Probably, but there would always be that little nagging voice in my head that says, maybe not.
With all the electronics on cars these days, I'd always wonder if there is any kind of very small constant 'keep alive' drain for any part of the electronics that over a period of a few months would be enough to drop the voltage just enough to prevent the battery from having enough capacity left to crank it over fast enough to start the engine.
You'll never know for sure until it's time to start the car, and if it doesn't start, you'll be kicking yourself for not having the small battery tender.
Old 02-27-2014, 12:00 PM   #10
Bulldog3071
Drives: 2010 Camaro 2SS/RS LS3
it will start right up, need let in run in storage every once and a while, mine is not a daily driver and I run it in the garage at least once in a while I have gone 4-5 weeks without running it
Bulldog3071 is offline   Reply With Quote
Old 02-27-2014, 12:10 PM   #11
KBsSS
KBsSS's Avatar
Drives: 2013 Corvette 2LT
I go once a month and drive car up and down INT 376. No problems starting up even with temps in low to - temps.
KBsSS is offline   Reply With Quote
Old 02-27-2014, 12:28 PM   #12
baum
Drives: 2013 1LS, 2013 Ram 1500
i stored mine last nov. same thing nothing done to it. i started it in Jan once and no problems at all.
baum is offline   Reply With Quote
Old 02-27-2014, 12:31 PM   #13
DRKS1D3
DRKS1D3's Avatar
Drives: '17 Corvette Grand Sport M7
It will be fine. Mine has been sitting in my garage since November (no Tender) and has not been started. Last weekend, I started it and backed it out to let it run for 15-20 minutes. It fired right up with no problems. The average temp. here over the past 3 months has been around 25 F and my garage is NOT heated.
MY RIDE: 2017 CORVETTE GRAND SPORT--TRIPLE BLACK, 7 SPEED MANUAL, VARARAM TCR-7 INTAKE, BORLA CATLESS X-PIPE, CARBON FIBER STAGE 2 AERO, MGW SHORT-THROW SHIFTER
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ
DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE
"Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!".
DRKS1D3 is offline   Reply With Quote
Old 02-27-2014, 12:33 PM   #14
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: 2010 SGM Sp. Edition 2017 RS Conver
It will start.
its a syn is offline   Reply With Quote
