Old 07-27-2009, 09:54 PM   #1
ToddSS
ZZ Motorsports Sales Rep
ToddSS's Avatar
Drives: 2010 SIM 1SS
Looking for Forged Rods and Pistons for L99
Just as the title says. Anybody come across a maker yet? I've done a few searches and come up with nill.
ToddSS is offline   Reply With Quote
Old 07-27-2009, 10:07 PM   #2
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Drives: 2011 2SS/RS LS3
Are the pistons and rods any different on the L99 than the LS3? If not, then all the major players have them...JE, Diamond, Wiseco, SRP, Lunati, Oliver, etc...
Kilo-9 is offline   Reply With Quote
Old 07-27-2009, 10:08 PM   #3
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Also, you may look at forged LSX internals from GMPP.
Old 07-27-2009, 10:17 PM   #4
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
if your going to change the rods and pistons, you might as well get a whole kit, crank rods, pistons and make it a stroker and add some displacement ,, you would have to have the new rods/pistons balanced to your stock crank anyways
Old 07-27-2009, 10:20 PM   #5
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
How about a gm part #19170988 for the crank and and part #12603616 for a crank
And for the connecting rods we have from 6.0" to 6.2 " hear you go
6.000" # 19166964
6.100" # 19166965
6.125" # 19166966
6.150" # 19166967
6.200" # 19166968
Old 07-27-2009, 10:39 PM   #6
rodimus prime
Drives: Cargo van.
The pistons are different. Or at least they have exhaust valve relief cuts in them. But the crank and rods out of the ls9 would work. Infact a ls9 is an ls3 with different crank rods and pistons....plus a supercharger.
rodimus prime is offline   Reply With Quote
Old 07-27-2009, 10:42 PM   #7
camaro1
camaro1's Avatar
if you went with aftermarket pistons they valve relief's wouldnt matter, the heads on the l99 and ls3 are the same, and the pistons would have the LS3 / l99 valve reliefs in them
really i just dont think the work needed to change just the rods and pistons and have the whole rotating assy re-balanced would be worth the labor, unless you gained some ci in the process
Old 07-27-2009, 10:50 PM   #8
2SSRS@Gen5diy
The rods on the ls9 are forged titanium Part #12624231
Old 07-27-2009, 10:53 PM   #9
rodimus prime
Drives: Cargo van.
The l99 has valve reliefs due to VVT. The ls3 doesnt have relief, thus the higher compression ratio.
Old 07-27-2009, 11:05 PM   #10
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
0.3 cr. woohoo the L99 is a natural born KR killer.
hot ss is offline   Reply With Quote
Old 07-27-2009, 11:07 PM   #11
rodimus prime
Drives: Cargo van.
Better for boost
Old 07-27-2009, 11:17 PM   #12
hot ss
hot ss's Avatar
yarrrr.
Old 07-27-2009, 11:24 PM   #13
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Any aftermarket piston should be available with valve reliefs...
Old 07-27-2009, 11:56 PM   #14
PatrickfromMD
PatrickfromMD's Avatar
Drives: Buick Enclave/Corvette/2010 Camaro
Personally, I would look for pistons with larger reliefs, so I could run a cam with more lift, more duration, or with less phase limiting.
The VVT is a technology that has yet to be fully tapped
I’d probably look to supercharge as well, so the lower compression due to deeper reliefs would be ideal for me.
(i.e. forged with deap reliefs or dish for about 9/1 compression and more clearance for a better cam…30 degrees phase limiting perhaps?)
***56K miles and still going strong***
2SS/RS IOM ext w/cyber grey stripes, tinted windows, IO int Auto
ProTorque prototype Converter, Chuck Mosello of Westchester Corvettes Custom Tune
T&T installed SLP Longtubes, Powerflow X Pipe, and Powerflow axle back
JL 10W3 in custom side sub box, new door tweeters, Alpine 5ch 600 watt
T&T configured ACS front Fascia w/ heritage grill, splitter, dual color halos, , led markers, taillight bezels , all accented in CGM
Gary Custom Z vented fenders. Vararam ver 2
PatrickfromMD is offline   Reply With Quote
GMPP Camshaft Camaro_Psycho Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-11-2009 01:58 AM
Camaro SS Questions. 500-600hp possible on stock internals? Gone Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 36 04-22-2009 09:04 PM
