Old 07-28-2009, 03:13 AM   #1
Looking Good in Red
Looking Good in Red's Avatar
Drives: Pewter 2000 T/A
Send a message via AIM to Looking Good in Red
Idle trouble
Forgive me if someone has already posted this. I have searched and could not find anything.
Does anybody know why on a 1998 v6 when hot (210) the idle will fluctuate greatly? I'm talking dropping to 800-900 RPMs, then going back up to 1400-1500 then back down. It only does it at idle and when the car is really hot. It almost sounds like the car is at first starting to die, then tries to pick itself back up, then wants to die again.
I went to AutoZone and the guy there said that it may be the Idle air control valve. Is this a possible suspect? Can I just pull it out and spray some brake cleaner on it to try to clean it off without damaging it?
Help would be appreciated!
Looking Good in Red is offline   Reply With Quote
Old 07-28-2009, 04:24 AM   #2
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
Sounds like you need a new fuel pump and fuel filter.. Those would be the first two I'd replace considering how old your car is and those parts when they start to fail do make the car act the way you are describing.
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
High Performance Exhaust AntmanZ28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 94 08-22-2009 03:16 PM
Random idle trouble on 96 SS AquaBlue6 4th Generation Camaros 4 07-27-2009 02:58 AM
Trouble taking key out on NEW 2010!!! scajc Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 12 07-20-2009 12:11 PM
V6 engine idle showcamaro Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 9 06-17-2009 05:03 PM
Polished Aluminum Wheels and the V6 Idle KJS 5th Gen Camaro SS LS LT General Discussions 13 06-12-2009 10:45 PM
