Old 03-01-2014, 09:23 PM   #1
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
My "Pre-Owned" Magnacharger install experience
Just thought I'd share for the benefit of anyone else buying a used Maggie setup, as I've installed several new kits, but never a used one, so there are a few things I didn't notice when I was looking at the kit I bought.
First, I decided to go ahead and port the lower manifold. I've done it before on a new kit, but as I said, this is my first use of a used kit. this is what I found:
I guess the previous owner didn't have a catch can installed. You can see the little pool of oil in the spot where the intercooler "buttons" go that hold the intercooler up. So I went ahead and blasted the manifold before I started porting it. I ported one runner before deciding it was just too much to do all over again. Last time I did one, I did it all by hand. Took FOR-EV-ER. So I decided to rough out the ports with the mill.
Saved HOURS of time with the carbide burr. Milled it out in 45 minutes. One setup shown in the picture, and one from the inside of the manifold that leveled the port floor with the machined area under the intercooler. You can see some of the difference here in this inside shot, that shows the new o-rings required when reassembling the upper and lower manifolds.
I have the sizes required written down somewhere in the shop for anyone taking this on in the future.
Next on the list was pieces I had to come up with. I was so excited to get the blower I didn't go through the instructions enough times to catch everything that should have been in the kit that I didn't get. This was: The throttle body extension harness, the MAP extension harness, the coolant pump relay harness, and the 76mm tensioner pulley. The first three weren't too bad, I've done 12V wiring for a long time, both as a hobby and professionally, so a little soldier and heat shrink did the job for me, but for someone else, maybe not so easy. On the relay harness, I had the plug and leads for the pump, so I only had to scare up a 30A standard 12V relay that I had laying around, and a couple female spade terminals, and more heat shrink and soldier, along with some 1/4 wire loom. On the tensioner pulley, I've found that a 2003 silverado tensioner is the right size and everything, and only about $16 locally. It is required to get maximum belt wrap around the drive pulley. I'm not getting any belt slip even though I haven't put the smaller pulley on yet. However, it made installing the brand new belt almost impossible.
2012LS3VERT is offline   Reply With Quote
Old 03-01-2014, 09:42 PM   #2
2012LS3VERT
Next on the list: some possibly time saving tips.
I was able to do the full install without draining my radiator, as I have a 2012, so the heater hoses aren't in the way of the blower. The instructions don't mention this. All I had to do was remove the line from the nipple at the radiator cap while I did some work in that area, I clamped it off with vise grips, as it goes to the steam line that will drain if not clamped off. I then leaned back the radiator to install the intercooler. I also did not remove the fans, as that would have required draining the radiator as well. I still had enough room to install the pin kit in the crank with my right angle cordless drill. I was able to scare up a pin kit relatively cheap, but I could have gotten it cheaper buy just using two dowel pins that I have in stock at work, A used kit without the pins, and a new crank bolt from the dealership. Would have saved about $30.
I also did not have the valley plate that magnacharger provides for the LS3 motors. I reused the LS3 plate by turning the PCV nipple downward and doing some minor grinding to the nipple boss on the plate. The real interference issue is the ribbing on the underside of the lower manifold. 3 minutes with the die grinder was better than removing and reinstalling the plate anyway.
On the oil pressure sending unit, there is a copper crush washer that is included to index the wiring clip it a certain direction to prevent interference. Of course, not included in my used kit. I was able to make one from teflon sheet and a gasket punch set at work. I think it was 3/32 thick, with a 9/16 center hole and 1" OD. I added a little extra thread tape and some RTV on the washer for good measure. No leaks here!
Lastly, on the issues of the convetible strut tower brace and radiator support brace: I did not have the spacers that Magnacharger includes for the radiator support brace. I had the bumper off for my install, so I was able to use some spacers I machined at work along with some longer bolts and washers. I also placed some weatherstripping tape between the heat exhanger and brace to make me feel better about the possibility of them contacting each other (they had clearance without the the tape, though):
Contrary to what I have read is some places (including the magnacharger instructions), the strut tower fits right back, no problems.
Old 03-01-2014, 10:35 PM   #3
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
I didn't read your whole post very thoroughly, but there's something I think you didn't mention doing, that I would've recommended, and that's testing the heat exchanger (under the blower) for leaks. Unbeknownst to me, mine had a small leak that wasn't visible to the naked eye and I'm lucky I didn't blow the engine before my shop figured it out. Keep an eye on your Maggie's coolant reservoir and an ear out for any whirring/howling-wind noises--a clear sign of no coolant in your system.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 03-02-2014, 02:08 AM   #4
jvoisel
Drives: 2010 2SS/RS M6
Nice writeup man! I bought my kit used too and was missing pretty much everything you listed.
Do you have any more pics of the ported lower manifold? Thinking about pulling mine off and doing the same.
2010 2SS/RS
jvoisel is offline   Reply With Quote
Old 03-02-2014, 10:33 AM   #5
2012LS3VERT
I'm not sure if I have more pics, lll have to look. And I did check the intercooler for leaks, as the car I bought my kit off of was in a wreck, I should have mentioned it up top.
Old 03-02-2014, 11:08 AM   #6
Bo White
Bo White's Avatar
So is it road worthy now?
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 03-02-2014, 11:50 AM   #7
2012LS3VERT
Oh yeah, I'll be headed up to T-town with the top down this afternoon!
Old 03-02-2014, 04:00 PM   #8
Bo White
Bo White's Avatar
Well come on up!
Totalled:
Old 03-02-2014, 11:37 PM   #9
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
I stopped by Dreamland's this weekend. Lot of good hangouts in Tuscaloosa .
UNRIVALED SS is offline   Reply With Quote
Old 03-03-2014, 03:40 AM   #10
Bo White
Bo White's Avatar
Next time through give me a holla
Totalled:
Old 09-21-2014, 10:57 PM   #11
fastsspr
Drives: Red SS
You have any data on 1/4 mile or HP improvement ?
fastsspr is offline   Reply With Quote
Old 09-21-2014, 11:11 PM   #12
2012LS3VERT
Sure. With the blower, and a couple other items, I made 545 HP/565 TQ at the wheels with 10.5 psi.
Old 09-21-2014, 11:32 PM   #13
forklord
forklord's Avatar
Drives: 2010 2SS
seems awfully low for over 10 psi?
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 09-21-2014, 11:33 PM   #14
2012LS3VERT
With stock manifolds.
