Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Audio / Visual / Electronics/ Gauges / Nav
Old 03-03-2014, 09:18 AM   #1
SNSSTR
All About That Speed
SNSSTR's Avatar
Drives: 2010 Camaro 2SS/RS
WTT 2 Blue Interceptors for 2 Red
Purchased two interceptor gauges with blue displays about a month and a half ago. I just installed them last night.
Not really fond of the blue display, I'd like to go with red.
So if anyone has red interceptors and wants to do a straight up trade for some blue ones, let me know.
Here's a pic from last night right after I installed them.
2010 SS M6 | 416 CI | H/C/I | GPI TUNED | SNSSTR
SNSSTR is offline   Reply With Quote
Old 03-03-2014, 09:37 AM   #2
paparz
Drives: lamo doors
are you interested on selling them ?
can you pm me back the price to 23901 please.
thank you very much
paparz is offline   Reply With Quote
Old 03-03-2014, 09:56 AM   #3
SNSSTR
SNSSTR's Avatar
Pm sent
Old 03-05-2014, 12:27 PM   #4
SNSSTR
SNSSTR's Avatar
Bump
Old 03-07-2014, 10:02 AM   #5
SNSSTR
SNSSTR's Avatar
Bump, also willing to sell these for $380 shipped in the continental us. Would include gauges, cables, black and white faces, original box, everything.
Old 03-07-2014, 11:36 AM   #6
13FastBlkSS
Drives: 2013 Camaro 2SS/RS M6
What options do those gauges have?
2013 Black / Black Camaro 2SS/RS M6 w/Magnuson TVS2300, ZL1 Fuelpump / ADM FPCM, NPP Exhaust, Cold Air Inductions CAI w/ Scoop, Elite Engineering Catch Can, VMAX Ported TB, OEM 1LE Front Splitter, AAC Ghosted Side Markers, Dropped on BMR Split Drop Springs
Build#24869
13FastBlkSS is offline   Reply With Quote
Old 03-07-2014, 11:43 AM   #7
jvoisel
Drives: 2010 2SS/RS M6
To name a few..
  • RPM
  • MPH
  • Intake Air Temperature (post Intercooler)
  • Ambient Air Temperature (pre Intercooler)
  • Engine Coolant Temperature
  • Exhaust Gas Temperature (PCM Calculated)
  • Transmission Temp. (auto trans)
  • Manifold Pressure (vacuum/boost) displayed in PSI
  • Fuel Temperature
  • Battery Voltage
  • Battery Temp
  • Injector Pulse Width in msec.
  • Injector Duty Cycle (%)
  • Air Flow Rate into engine
  • Long Term Fuel Trim
  • Short Term Fuel Trim
  • O2 Sensor Voltage
  • Barometric Pressure
  • Ignition Advance
  • Base Spark
  • PCM Spark Adjust
  • Fuel Status (open/closed loop)
  • Wastegate Solenoid Duty Cycle (%)
  • Knock Retard
  • Knock Sensor Raw Voltage
  • Throttle Position Percentage
  • Throttle Position Sensor Raw Volts
  • Calculated Net Horsepower
  • Engine Load
  • Transmission Slip
  • Current Transmission Gear
  • Torque Delivered to Transmission
  • Torque Converter lockup status
  • Brake pressure
  • Brake Booster Travel
  • Steering Angle
  • Non-driven Wheel Speed
  • Lateral G's
  • Yaw
  • Fuel economy (instantaneous and average)
  • P-ratio - pressure ratio MAP/Barometer
  • 2 user configurable analog inputs**
and more.
2010 2SS/RS
jvoisel is offline   Reply With Quote
Old 03-07-2014, 01:09 PM   #8
SNSSTR
SNSSTR's Avatar
Originally Posted by jvoisel View Post
To name a few..
  • RPM
  • MPH
  • Fuel Temperature
  • Battery Voltage
  • Battery Temp
  • O2 Sensor Voltage
  • Ignition Advance
  • Base Spark
  • PCM Spark Adjust
  • Knock Retard
  • Engine Load
  • Transmission Slip
  • Brake pressure
  • Steering Angle
  • Lateral G's
  • Yaw
and more.
Thank you sir I appreciate the assistance!
You can also data log for 30 seconds at a time, record 0-60, 1/8th mile, and 1/4 mile runs. The gauges can check and clear CEL's. You can set up alerts with the bright led lights on them for a shift light or a warning on any parameter.
I love the gauges, just want red
Old 03-09-2014, 09:05 PM   #9
SNSSTR
SNSSTR's Avatar
SOLD
