03-03-2014, 10:06 AM | #1 |
Drives: 1983 Berlinetta Join Date: Mar 2014
Need help. Looking for parts
I'm trying to find a blower motor resistor without A/C for my 83. Every where I've gone to or looked at doesn't have one. There are no You Pull its in 50 miles that have my car. If anyone can find one please hook me up. Thanks
03-03-2014, 09:39 PM | #2 |
Drives: 69 Camaro and 92 RS Join Date: Feb 2013
Who's your local auto parts store? take your pick. From what i can tell the roundish ones are for a/c and the rectangle shaped ones are for your non a/c car.
http://www.autozone.com/autozone/par...82169_0_0_6774 http://www.autozone.com/autozone/par...06198_0_0_6774 http://shop.advanceautoparts.com/p/f...019%7CL3*15900 http://www.oreillyauto.com/site/c/de...motor+resistor
There are 3 ways to do any project. Good, fast, and cheap. You can only choose two.
If it's done good and fast, it isn't going to be cheap. If it's done good and cheap, it isn't going to be done fast. If it's done cheap and fast, it isn't going to be good. |
03-04-2014, 08:09 AM | #3 |
The original one pulled of the car is rounded like the ones with A/C. On top of that the spot where it mounts is also rounded. Furthermore I have looked at all those parts stores and none of them have what I am looking for. Hence the reason I am posting here. Thank you for your input though.
03-04-2014, 12:22 PM | #4 |
Did the car have a/c when built and a previous owner remove it?
When I get home I can look up the RPO for air conditioning on an 83 if that would help you.
03-04-2014, 10:03 PM | #5 |
If you check your RPO codes, the code for air conditioning in '83 was C60. 128,798 of the 154,381 camaros made in '83 had A/C. Your code sheet should be on the underside of your center console lid.
Check that and let me know.
04-04-2014, 07:04 PM | #6 |
I go through ricks ecklers camaros,summit racing,n classic industries for parts for my car have u tried them
Tags |
1983 camaro, blower motor resistor |
