Old 03-05-2014, 12:56 PM   #1
45thVert
Drives: 45th Anniversary Camaro 2LT RS Vert
V6 Camaro Noob Question
Hey Guys,
Sorry for the noob question but this has been bugging me. I feel like my automatic v6 camaro takes way longer to shift from 2nd gear to 3rd gear, and I have to hit about 7000rpm in order for that shift to happen.
Thanks for the help!
45thVert is offline   Reply With Quote
Old 03-05-2014, 01:03 PM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
7K , my friend you have an issue.
Even punching it in sport mode won't get to 7K.
FSP tuned: 377/389
Old 03-05-2014, 01:05 PM   #3
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
are you in manual mode? lol
Old 03-05-2014, 01:06 PM   #4
dmginc
dmginc's Avatar
Drives: In Circles
either you have your foot to the floor or a vacuum leak.
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 03-05-2014, 01:08 PM   #5
nyrfan
Let's go Rangers!
nyrfan's Avatar
I was thinking that it does not auto shiift up in manual mode.
FSP tuned: 377/389
Old 03-05-2014, 01:12 PM   #6
PoorMansCamaro
Drives: Really Slow
Even still it's not likely getting to 7K.
yeah, I don't have much experience in an auto, doing manual mode. so you can bounce off the limiter in an auto?
Old 03-05-2014, 01:13 PM   #7
nyrfan
Let's go Rangers!
nyrfan's Avatar
Yep, you'd bounce!
FSP tuned: 377/389
Old 03-05-2014, 01:14 PM   #8
colingordon
Her Name is Mila
colingordon's Avatar
Drives: 2012 Camaro 1LT A6, 2014 Camaro 1LS
when you get to redline it just defuels the engine until it is not a redline anymore
colingordon is offline   Reply With Quote
Old 03-05-2014, 01:15 PM   #9
PoorMansCamaro
Drives: Really Slow
Yep, you'd bounce!
then yeah, i'd take the car to the dealer. if you are just driving normal, and the car is revving anywhere near 7k rpm, you have a problem.
Old 03-05-2014, 01:41 PM   #10
KMPrenger
KMPrenger's Avatar
Actually, getting close to 7K in the V6 (even the automatic) is pretty easy...punch it or go into manual mode and she will bounce off the limiter at 6,800 to 6,900 easily. So 7K is not out of the realm of possibility.
To the OP,
If your car NEVER will shift, even while in automatic mode, until redline then you have a problem. Take it to a dealership.
Old 03-05-2014, 01:57 PM   #11
nyrfan
Let's go Rangers!
nyrfan's Avatar
To the OP,
I know when you punch it you'll get "close" to 7K, I guess my point was normal driving (which I assume the OP is referring to) should get you nowhere near 7K.
FSP tuned: 377/389
Old 03-05-2014, 02:54 PM   #12
DefianceDan
VroomVroom
DefianceDan's Avatar
Drives: 2017 50th 2SS
OP - throw it into M and don't touch the tap shifters. This puts it in sport mode (i.e. 1000% more fun than D)
2017 H50 2SS MX8 F55 NPP CF5 RN2
DefianceDan is offline   Reply With Quote
Old 03-07-2014, 08:53 AM   #13
abaucom21
Drives: 2011 2LT White, 1966 TBird conv.
Same issue with my 2011 2LT A6 when new. GM replaced TCM (transmission control modual). That fixed the issue.
abaucom21 is offline   Reply With Quote
Old 03-07-2014, 10:54 AM   #14
RubyCamaro
Jan
RubyCamaro's Avatar
What he said. I always drive in sport mode (shifter position in "M" and don't touch the paddles). There is a lag in some shift points even in S, worse in D. A ported throttle body will help with that. But it should not be nearly that high RPM's in D or S before shifting, driving normally. Now at WOT, maybe. As others have said, see your dealer if you are getting that high in RPM's in normal driving before it shifts.
automatic, shift
