Old 03-06-2014, 02:49 PM   #1
sac130e
Drives: 2014 Camaro SS/RS BRM
Torque the Lug Nuts?
Does anyone actually torque the lugs when they put their wheels back on?
I never have, but I also put more behind the tightening then I probably should. Just wondering if I should try torque instead of cracking too much on them.
P.S. What it the actual torque for the lugs anyway?
Thx
sac130e is offline   Reply With Quote
Old 03-06-2014, 02:53 PM   #2
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Service manual says 140 ft-lbs
Factory installs them at 100 ft-lbs
I install them at 110 ft-lbs
Yes, you should always torque lugs. Uneven can cause the looser ones to work loose over time, and uneven can also cause brake rotors to warp.
Fquick.com/NineBall
Old 03-06-2014, 02:55 PM   #3
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Thx
Yes you should always torque your lug nuts, if you don't tighten them evenly you could warp the wheel or rotor. It has happened to me on my HHR at a discount tire place when they used the air wrench to tighten them instead of snugging them up first then using a Torque wrench to finish the job. Always also use the Star method to tighten them.
The torque specs should be listed in the owners manual. I will check and see.
I just checked, the owners manual says 110 ft lbs.
The Bird is the word!
Old 03-06-2014, 02:59 PM   #4
Bo White
Bo White's Avatar
I do and when I was a mechanic I used torque sticks on every car I worked on.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 03-06-2014, 08:00 PM   #5
MyRideIsHere
MyRideIsHere's Avatar
Drives: 98 z28, 13 LS, 14 SS, 14 ZL1
Torque'm... Star pattern... Take your time... Run'em a 100 miles, check the torque... Good to go...
This is what is IN MY MIND...
Your Mind May Vary
MyRideIsHere is offline   Reply With Quote
Old 03-06-2014, 09:03 PM   #6
GMTool
MY SS is SOLD
GMTool's Avatar
Drives: AGM 2012 Camaro 2SS/RS L99
Yes I do.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
GMTool is offline   Reply With Quote
