03-08-2014, 08:52 AM | #1 |
Drives: 10 LS3 2SSRS IOM,21 ZLE Wild Cherry Join Date: Aug 2009
Need input: Radiator Fan harness connector melted
Looking for info about problems with 2010/2011 Radiator fan wiring harness connector failures (burnt/melted). The fans work fine and no fuses burnt, and no fuses ever changed to higher amps either.
Here's the dilemma...... in 2012 or 2013 the harness and fans changed. The 2010/2011 harness is a flat connector at the top of the radiator with black fans, the 2012/2013 is a square connector with white fans. In order to get a new harness, it has to be ordered with the drivers side fan since it is hardwired into the fan, but has a connector for the passenger side. Who has experienced this problem and does anyone know if the newer fans/harness are an actual improvement or could it be simply that Chevrolet changed manufacturers for cost and/or production reasons? The other option is upgrade to the Ron Davis dual pass radiator that comes with fans.
860 RWHP 924 RWTQ,TVS2300 10/14 OD 2.75/NW 102mm,RDS/FLOWED "109" SHOT/LPE NCC NLP spoiler/GM splitter/Torq HE-fans/oil coolers/IC1000cc Squash twins,GT9,Coil Covers,Mats,Pedals/ADM Gauges,Race Scoop/Trunions DDS CVs,Carbon F DS/RPM L6/LPE 9.5 3.73/Pedders HD bushes,align kit RB 2-piece rotors,S/S Lines,Hawk HPE Pads/Forgeline SP3P/Weld RTS Ceramic ARH 2" LT/3" X-pipe,Corsa Touring/BMR TA,Toe,LCA,DS Loop StreetSlayer BC3/MTI Shifter-Trans mt/Hotchkis CB/Monster CC/SJM LineLock PFADT Coil Overs,Sways,Links,Mounts,SF Bushes,Camber Kit LPE Brotherhood . Last edited by Blue70SS; 03-08-2014 at 09:12 AM. |
03-08-2014, 08:54 AM | #2 |
Here's the new style fans and harness/connectors
Connectors are square and fans white
860 RWHP 924 RWTQ,TVS2300 10/14 OD 2.75/NW 102mm,RDS/FLOWED "109" SHOT/LPE NCC NLP spoiler/GM splitter/Torq HE-fans/oil coolers/IC1000cc Squash twins,GT9,Coil Covers,Mats,Pedals/ADM Gauges,Race Scoop/Trunions DDS CVs,Carbon F DS/RPM L6/LPE 9.5 3.73/Pedders HD bushes,align kit RB 2-piece rotors,S/S Lines,Hawk HPE Pads/Forgeline SP3P/Weld RTS Ceramic ARH 2" LT/3" X-pipe,Corsa Touring/BMR TA,Toe,LCA,DS Loop StreetSlayer BC3/MTI Shifter-Trans mt/Hotchkis CB/Monster CC/SJM LineLock PFADT Coil Overs,Sways,Links,Mounts,SF Bushes,Camber Kit LPE Brotherhood . |
03-08-2014, 09:03 AM | #3 |
Drives: G5.R Join Date: Sep 2010
Looks like all you need to do is replace the connectors. You can use any four wire connector. They don't have to be factory connectors. Any wiring guy should have some that they can replace these with. Or call Casper Electronics and ask them to send you replacement connectors. Speak with Brandon.
03-08-2014, 11:42 AM | #4 | |
