Old 03-09-2014, 07:55 PM   #1
LagunaSecaZL1
LagunaSecaZL1's Avatar
Drives: 2013 ZL1 M6
DIY Cup holder Delete - Cover - $25
Hey, I saw two threads on Cup Holder deletes.
http://www.camaro5.com/forums/showth...pholder+delete
and
http://www.camaro5.com/forums/showthread.php?t=268163
I wanted to make a quick version for myself. My reason is that I am 5' 8" and my elbow hits the corner of the cup holder/console lid, especially on the 1-2 shift. I do not use my car for long trips and do not drink coffee on my way to work. If I want, i can remove the upholder delete in about 3 seconds.
Here are the materials, and pictures.
It took about an hour to make.
Materials-
Craft paper for template
2' x 4' x 3/4" MDF board (smallest size at Home Depot) $11
Vinyl from Joanne's Fabrics (wife bought it for me about $10)
Interfacing (white padding)
Staple Gun
Jig saw
Right angle air grinder (sanding discs)
Steps-
1. Make template out of craft paper
2. Trace template onto MDF board and cut out with jigsaw
3. Set jigsaw to 45 degree angle to bevel edge
4. Sand with air grinder as necessary, trial fit
4. Cut interfacing(padding) to match top
5. Staple vinyl to MDF board
6. Marvel in your fabrication ability
Now you can power shift into second with out your elbow jamming into the console cover!
Corvette Z06/Z07/M7 (2016) Late Model Racecraft Intercooler reservoir and 160* Thermostat.
Sold- 2013 Camaro ZL1 M6 (Black on Black), Detroit Speed Sway bars, DOT 4 Brake Fluid, separate clutch master reservoir, Moroso Catch Can. 2.11 at Thunderhill 100* ambient. Ron Davis Radiator and AFCO Heat Exchanger installed after track day, Roto-Fab CAI.
Sold- 2001 Mustang Cobra -Griggs GR40,M5, Torsen T2-R, 4.10, 14" Brembo fronts, high 1:40s at Laguna Seca
LagunaSecaZL1 is offline   Reply With Quote
Old 03-09-2014, 08:18 PM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
would be nice if the stitching would match along with the leather color....after all it is a ZL1....but i like it nice work
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 03-09-2014, 10:05 PM   #3
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
Ha ha ha, dude that is awesome!
I bought one of these from RPI, cost around $40.
I wish I had the insight to just make my own as you did.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 03-22-2014, 08:47 PM   #4
djcfuzz
Do somethin fun every day
djcfuzz's Avatar
Drives: 2012 45th V6 RS M6
Mine is here:
http://www.camaro5.com/forums/showthread.php?t=328286
Staples work as well. I would cover those staples with a glued piece to avoid scratching the cupholder plastic.
djcfuzz is offline   Reply With Quote
Old 03-29-2015, 03:55 AM   #5
cammy2013
Drives: 2013 camaro
Do you think you can upload a template for the cup holder
cammy2013 is offline   Reply With Quote
Old 03-29-2015, 08:42 AM   #6
Ryan2ss
Ryan2ss's Avatar
Drives: 2ss camaro m6 inferno orange
I did the same thing but I recessed the center to fit my Samsung s5 and glued in a charger so when you slide the phone in it is also charging. was a fun little project
Ryan2ss is offline   Reply With Quote
cover, cup, delete, holder, upholder
