03-10-2014, 07:21 PM | #1 |
broke a vac line connection please help.
I was running new line to get rid of the plastic tubing and I snapped off the plastic part going in to the manifold. Anyone know how I could possibly fix this. Possible drill and tap it and put in a threaded hose connector. Sorry the picture is turned. It's the inlet right behind the throttle body.
03-11-2014, 01:28 AM | #2 |
Banned
Drives: ... Join Date: Dec 2013
Drill tap and use a barbed fitting. You can always epoxy the fitting in as well.
03-11-2014, 08:17 AM | #3 |
Drives: 2023 2SS Convertible Join Date: May 2009
JB weld?
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold! '23 2SS Convertible -Same as above except orange. |
03-11-2014, 08:54 AM | #4 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
I did the exact same thing when I was doing my own cam install. I used super glue and just put the piece that broke off back on, hold it in place for a minute with pressure, mine was a clean break and fit right back in.
You dont need to drill out of put a barbed fitting or something. I then put some silicone around the break to make sure it was sealed. Ive had zero issues with it. |
