Old 07-29-2009, 07:45 AM   #1
Kwaz1335
The Kwaz
Drives: Black 2010 Camaro 2SS/RS
Send a message via AIM to Kwaz1335
Common tools explained..a must read for any gearhead
Common Tools Explained
To the unitiated, the workshop can be an intimidating place, full of tools you may not know what to do with. To help, here's a helpful explanation of common tools and their uses.
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted vertical stabilizer which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light . Also removes fingerprints and hard-earned cleco calluses from fingers in about the time it takes you to say, "Oh sh*t!"
ELECTRIC HAND DRILL:
Normally used for spinning pop rivets in their holes until you die of old age.
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES:
Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles...used for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4:
Used for levering an automobile upward off of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR:
A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good aluminium sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER:
A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS:
See hacksaw.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids and for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
MECHANIC'S KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
DAMMIT TOOL:
Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs. It is also, most often, the next tool that you will need.
Ordered:3/13/09
1100: 3/13/09
3300: 5/12/09
Picked up and brought home 6/26/2009
2010 Black on Black SS/RS Camaro
Silver stripe package
Ground effects package
6 Speed Manual Transmission with Hurst short throw, Magnuson Supercharger, SLP loudmouth 1 kit.
Kwaz1335 is offline   Reply With Quote
Old 07-29-2009, 07:57 AM   #2
2SSJIM
2SSJIM's Avatar
Drives: 2012 CRT ZL1 #1400
Other uses of Vise Grips: Tool used to hold rusted out fenders on old jaloppy cars in northern snow covered areas that lay salt on the roads!!!!
2SSJIM is offline   Reply With Quote
Old 07-29-2009, 11:27 AM   #3
SleepWarz
Banned
Drives: 1991 New Yorker, 69 Tbird, ABM2SSRS
rofl nice.
I'm surprised I didn't see the crescent wrench
CRESCENT WRENCH: A very special tool that can be used to bust your knuckles on any hard solid object that lies near what your working on.
SleepWarz is offline   Reply With Quote
Old 07-29-2009, 01:02 PM   #4
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
DRILL PRESS:
Done that.. twice on a senior project and yest it was a Cessna Vert Stab
WIRE WHEEL:
Done that..
Burned one up trying that, instead had the description happen with a pneumatic..
SKILL SAW:
Or crew up a wing T-Brace..
PLIERS:
Haven't done this..
BELT SANDER:
Or stripping off rivet heads while being lazy on a repaint..
HACKSAW:
Don't forget the wire blades..
VISE-GRIPS:
I have NEVER used this tool.. ever. PITA..
WELDING GLOVES:
And really catch on fire easily..
OXYACETYLENE TORCH:
Did it..kinda..
TABLE SAW:
As the commercial said.. "I'm good.."
Or putting a hole in a new wing patch..
Screw that..get the 2 ton hoi-..wait a minute..
40 of these are the reason WMU is in debt.. (hint it wasn't just the tools..
BAND SAW:
or better yet just plain cut it wrong/backwards..
THERE IT IS!
Not to mention they..uh..bend..easily.
See hacksaw.
Yeah... about those three types of snips..
Hey, keeps the screw/bolt extractor people in business.. and me deaf.
Why do we even have these when everything is a stipout screw?
PRY BAR:
Or beating that poor C172 hulk to a..hulk.. after you've given up hope of getting that access panel off.
HOSE CUTTER:
You mean they actually cut?
HAMMER:
That, or the solution to pretty much every one of man's problems.
MECHANIC'S KNIFE:
Or to chase the idiot pilot away from the airplane after the 15th "It's not done yet.."
DAMMIT TOOL:
AKA the Damnit Car, the Damnit Bike, the Damnit Toaster, the Damnit C172R, the Damnit Piper Saratoga, the Damnit.. FAA..
Ah, I love tools..
Zabo is offline   Reply With Quote
Old 08-04-2009, 01:37 AM   #5
Kwaz1335
The Kwaz
bump
Ordered:3/13/09
1100: 3/13/09
3300: 5/12/09
Old 08-04-2009, 08:50 AM   #6
Jamie Mac
NCM-WINR
Jamie Mac's Avatar
Drives: 2010 SS/RS IOM 2014 2LT Stingray
In the service a bunch of us were standing in the shop debating the best way to repair a horizontal stabilizer. The one guy jokingly says "were going to need a metric crecent wrench". One kid who was dumber than a truckload of mustang owners said he'd get one. We all stared after him as he went to the tool room. Damned if he didndt come back with one that listed the max opening in metric
also drives a heavily modified Jeep Wrangler. It has LED headlights and wheel weights blacked out with Plasti Dip. It's Baller.
Jamie Mac is offline   Reply With Quote
Old 08-04-2009, 01:19 PM   #7
shank0668
shank0668's Avatar
PLIERS: Slips of objects and scratches paint on 78 Corvette.
Old 08-04-2009, 04:32 PM   #8
Dinksgirl48
Drives: 2010 2SS Red Jewel tint
LMAO and have forwarded list to my significant other for reference.
Dinksgirl48 is offline   Reply With Quote
