03-12-2014, 11:39 PM | #1 |
Drives: 2012 ZL1 Join Date: Mar 2014
295/40ZR20 Conti EC DWS
Wanting to put Conti Extreme Contact DWS 295/40ZR20 and 315/35ZR20 on my 2012 ZL1 stock rims. These are the only tires and sizes I can find that are all season but is 1.4 inches taller and .5 inches wider in the front going to rub?
Thank you in advance for your guidance. |
03-13-2014, 09:11 AM | #2 |
Faster than you...
Drives: 1194whp. 8.62@168. daily driver... Join Date: Nov 2013
You're completely good to go with the rear. I'm sure someone will chime in about the fronts.
GTR
03-13-2014, 09:52 AM | #3 | |
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300 Join Date: Nov 2011
03-13-2014, 09:56 AM | #4 |
Drives: 2013 Zl1 Join Date: Aug 2013
Is that the same set up Lingenfelter used on there zl1 to go 200mph?
2013 ZL1 Roto-fab cai, Apex catch can, Vmax LSA throttle body, Roto-Fab heat exchanger res, ATI balancer with 5% overdrive pulley, Stainless power 1 7/8" long tube headers.
03-13-2014, 10:12 PM | #5 |
Conti does have a 275/40/20 EC DWS but I'm concerned about going smaller in the front and bigger in the back. If you are running a 275 in front then whats on the back and is the handling change negligible? Is 275/40/20 and 295/40/20 the best option if I want to run the Conti ECs?
03-13-2014, 10:49 PM | #6 |
03-14-2014, 08:12 PM | #7 | |
REAR - 315/35/20 this set-up is just fine, no issues at all. this is my winter rims and set-up.. |
03-15-2014, 06:40 PM | #8 |
Thank you very much for the info…….
03-17-2014, 07:51 AM | #9 |
how is the traction compared to the gy's?
03-17-2014, 10:35 AM | #10 |
Well with temps under 50 degrees there is no comparison. The Conti's rule hands up. The coldest temp for me this winter driving the Camaro was 9 degrees F. No issues at all. You can't even think about that with GY's... I've only had the Conti's on since Sep last year.
03-18-2014, 10:22 AM | #11 | |
Drives: 13 ZL1 SIM, 99 Z28 Black Join Date: Feb 2013
Anyone notice that discount tire is changing to a Conti Control Contact Sport A/S. They say it works the same as the DWS. I am going to try a set on my wife's car.
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
