03-15-2014, 04:49 PM | #1 |
Drives: 2011 Camaro SS L99 Join Date: Jan 2012
Fuel Injector O-rings
First off, I searched w/o any luck.
I'm fixing to change out my L99 intake manifold for a ported/modded unit, and am wondering if I'll need to change fuel injector O-rings. Searched here and Internet for part numbers and availability and came up empty. Wanted to have a few spares in case they were needed during the swap. Does anybody know what the part numbers are and where they can be purchased? Thanks, Jeff |
03-15-2014, 05:06 PM | #2 |
Too much is never enough!
i change them anytime i remove them and replace any injector but thats just me i am sure others will chime in on it....sorry i dont have the part numbers
03-16-2014, 05:08 AM | #3 |
Jeff,
Just transferring the injectors and rail from one intake to the other, you won't need to change them. Just put a light film of lube one em when you reinstall. |
03-16-2014, 11:40 AM | #4 |
