Old 03-16-2014, 05:55 PM   #1
The_Blur
Moderator
The_Blur's Avatar
Why You Should Remove Spark Plugs During Header Install
I did not do so, and I suffered $15 worth of consequences. It could have been worse. These are for cylinders 5 and 7, the back spark plugs on the driver side of my L99.
The symptoms of this problem appeared a couple of minutes after install. The ride became very rough and there was a noticeable flutter sound that accelerated with engine speed. The vehicle was drivable, but it wasn't smooth and a "Service Stabilitrak" message appeared on the DIC, along with all 3 traction lights and a blinking CEL. The vehicle code read P0305. After fixing that, it read P0307.
The car has not read codes since.
warn 145:159 ban
Old 03-16-2014, 06:18 PM   #2
Denis
Denis's Avatar
Drives: 2010 SS
True story...
Old 03-16-2014, 08:16 PM   #3
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Happened to me too...cylinder 8
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 03-16-2014, 08:22 PM   #4
revived
Vrrrm.
revived's Avatar
Drives: 2011 2SS/RS LS3
How did you find out you cracked your plugs my car seems to run fine but has constant cel
revived is offline   Reply With Quote
Old 03-16-2014, 08:25 PM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Are you tuned? What codes are you throwing?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-16-2014, 09:47 PM   #6
revived
Vrrrm.
revived's Avatar
Not yet, haven't read them either.
Apart from the codes, are there any tell tail signs?
Old 03-16-2014, 09:59 PM   #7
axis
Search Ninja
axis's Avatar
Since you aren't tuned, your CEL is going to be the cat efficiency code. Nothing you can do about that until you get it tuned. That happens on EVERY SS that gets LT's and no tune. You may or may not have more than one code so it would be a good idea to get it checked at the local autozone or the like.
Halltech CF 102 fed
Old 03-16-2014, 10:17 PM   #8
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Yep don't be lazy. Pull your spark plugs first before you do a header install
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 03-16-2014, 11:39 PM   #9
Dexter9522
Drives: SS
^ what he said. And you will notice the car being a little sluggish. And service stabilitrak is usually a good indication u cracked one. Have it scanned an it will tell you which cylinder the issue is with. #8 for me when I did mine.
Dexter9522 is offline   Reply With Quote
Old 03-16-2014, 11:49 PM   #10
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
Yep, I installed my headers a few weeks ago and broke the same two plugs you did. One broke completely during install, and the other turned out to be cracked after I took it for a drive and got all the same warnings you did. I learned my lesson. Easy fix though, and I'm glad that's all it was. Enjoy the new headers!
Deke736 is offline   Reply With Quote
Old 03-16-2014, 11:53 PM   #11
RatedZ
RatedZ's Avatar
Drives: Camaro SS
Also, the motor when running will not only run loopy, but will vibrate. Easiest way to tell which cylinder is either not plugged in (the wire) or a damaged spark plug is to pull the plug on the coil pack and when you do if the engine continues to run loopy, try another. When you pull a plug on a coil pack and the engine calms down, that is your problem wire or plug.
RatedZ is offline   Reply With Quote
Old 03-17-2014, 12:22 AM   #12
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Thanks for the tip, I was wondering about that
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 03-17-2014, 01:39 AM   #13
Bo White
Bo White's Avatar
I've never pulled plugs on an LS car putting headers on. Lucky I guess.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 03-17-2014, 01:42 AM   #14
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS
Broke one also. Ran like it had a miss. Just one so it was an easy fix. I only ran it for a few minutes and never got a CEL or code.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
