Old 03-18-2014, 07:11 PM   #1
bansheekilla64
bansheekilla64's Avatar
Drives: 2013 Victory Red Camaro v6 1LS
Send a message via Skype™ to bansheekilla64
How long do you wait to warm up the car?
More specifically, what temperature should the "Coolant temperature" read before starting your car?
My rule was to always wait until it hits 100 and it seemed to be perfect. The oil temperature gauge would move up to a comfortable position to start the car.
Now, I've been doubting myself. Considering "Coolant Temperature" will never be at 100 during the spring/summer.
So, bottom line question: At what "Coolant Temperature" is it okay to start driving? In cold weather I'd say 100, but what about warm weather?
bansheekilla64 is offline   Reply With Quote
Old 03-18-2014, 07:35 PM   #2
amz
Factory Correct
amz's Avatar
Drives: 2011 2SS/RS
I am not sure what the temps read , but I take about 1 minute or so, to get all situated and cool looking.
amz is offline   Reply With Quote
Old 03-18-2014, 07:37 PM   #3
apeko
apeko's Avatar
Drives: 2011 2-SS/RS SGM
0.1 seconds for me..lol
2011: 2SS/RS Camaro Synergy Metallic
apeko is offline   Reply With Quote
Old 03-18-2014, 07:41 PM   #4
JamesMyBoy
Drives: 2014 2SS/RS
Wait long enough for the fast idle to come down, then drive like an old person until you see the temp gauge needle up off the bottom.
JamesMyBoy is offline   Reply With Quote
Old 03-18-2014, 07:45 PM   #5
jshaf
Montani Semper Liberi
jshaf's Avatar
Drives: 2011 Black 2SS/RS w/ IOM stripes
in colder days I let if warm for at least a couple minutes, try not to start it under 32 degrees, when it is summer time I just jump in start and drive.
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint
jshaf is offline   Reply With Quote
Old 03-18-2014, 07:45 PM   #6
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
there was just another thread on this same subject not more than a week ago....
fire it up and let your oil pressure build and idle come down...that is all you need to do
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 03-18-2014, 07:53 PM   #7
Zig Zag
Drives: 2014 1LT
About three minutes a little more in winter.
If I remember correctly most wear on a properly operating engine occurs within the first two to three minutes of start up.
Zig Zag is offline   Reply With Quote
Old 03-18-2014, 08:03 PM   #8
Mr. iNCREDIBLE
Mr. iNCREDIBLE's Avatar
Drives: 2012 2SS/RS Convertible
as long as it takes to turn the key and put it in reverse..
with a fuel injected motor and synthetic oil, warm up is not really needed.. HOWEVER.. I do live in Socal.. can't speak for you guys buried in snow..
I'm only responsible for what I say, not for what you fail to understand.
Mr. iNCREDIBLE is offline   Reply With Quote
Old 03-18-2014, 08:06 PM   #9
Texas_RS
Texas_RS's Avatar
Drives: 2013 1LE/SS
Lol.
Texas_RS is offline   Reply With Quote
Old 03-18-2014, 08:07 PM   #10
MYDLIFECRISIS
MYDLIFECRISIS's Avatar
So if it's 32*, you don't drive your car??
MYDLIFECRISIS is offline   Reply With Quote
Old 03-18-2014, 08:26 PM   #11
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
I ran this question by Ted Jannetty. He recommended that you wait until the coolant temp gauge starts moving, which for me, just so happens to be right at 100 degrees.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 03-18-2014, 08:27 PM   #12
Manbearpig
Engineer of softness-ware
Manbearpig's Avatar
Drives: 2013 2LT RS
I don't.
Manbearpig is offline   Reply With Quote
Old 03-18-2014, 08:46 PM   #13
ChevyGirl661
ChevyGirl661's Avatar
Drives: 2011 Camaro LS
ChevyGirl661 is offline   Reply With Quote
Old 03-18-2014, 09:14 PM   #14
Denis
Denis's Avatar
Drives: 2010 SS
Depends on the ambient temp. But I usually wait for the coolant temp to read at least 100.
