Old 03-23-2014, 03:26 AM   #1
Bryan2230
Bryan2230's Avatar
Drives: 2014 Red Hot Camaro 2SS/RS
******** Stealth install...
Hey guys just got the ******** stealth package from them. Package came with a 100A fuse, book for amp says to run an 50A fuse. My father is an electrician, though not an auto electrician, he said that I need to run a 50A because a 100A won't blow when the system needs it to blow.
Anyway, I have the system ready to go into the trunk, but the fuse question has me in, sort of, a waiting pattern.
Is it safe to use the 100A or should I wait and buy a 50A fuse?
Another question, Kit came with 16 gauge speaker wire, should I run a higher gauge, or is 16 gauge good enough? I have it wired with the 16 gauge for now. I read that how long the cable is should decide which gauge to use, I've used a 18" long wire from Sub to box, and 4" long wire from box to amp.
Last question is about the ******** 5th Gen harness, I noticed it has front and rear RCA connections, which ones should I run to amp?
Thank You,
Bryan
Former owner of a 2010 Victory Red 2LT/RS
Delivered: September 11, 2009
Current owner of a 2014 Red Hot 2SS/RS
Delivered: October 24, 2013
Bryan2230 is offline   Reply With Quote
Old 03-23-2014, 07:35 AM   #2
lfree11012
lfree11012's Avatar
Drives: 2018 1LE
Yes it is safe. Most amp have fuse on them or in them so if there is a problem with the unit or amp they will blow. The fuse is to protect the wire if there was a dead short betwen the batter and the amp this would stop that car from catching fire that way it should be close to the batter no more then 13 inc away.
lfree11012 is offline   Reply With Quote
Old 03-23-2014, 07:07 PM   #3
436SS
436SS's Avatar
Drives: 2010 1SS
Which package did you purchase?
436SS is offline   Reply With Quote
Old 03-24-2014, 10:40 AM   #4
Bryan2230
Bryan2230's Avatar
The one that comes with everything. Driver's side stealth, jbl sub, jbl amp, RCA convert harness. It's called the stealth package on the ******** website.
Sent from my iPad using Tapatalk
Thank You,
Bryan
Old 03-24-2014, 11:26 AM   #5
436SS
436SS's Avatar
Drives: 2010 1SS
O, ok. Let me know how that sounds, that seems like a pretty cool set-up.
Old 03-24-2014, 03:53 PM   #6
Eric Skiff
Drives: 2013 2SS 1le NPP
I just installed the same thing this weekend. I used the rear channel rca inputs. I also disconnected the front center speaker. It sounds pretty amazing to me.
Eric Skiff is offline   Reply With Quote
Old 03-24-2014, 06:38 PM   #7
Steve@Subthump
Drives: 2011 2SS IOM Vert
You can use front or rear rcas. It all depends if it is the stock amp and if you have moved the fader any. If you've replaced the amp altogether, then you should set the fader on zero and then it wouldn't matter.
If still using the stock amp, I typically use the front set because I fade my music to the front slightly. What happens is the rears get weaker and the fronts get stronger. So if your sub is attached to the rear set, the input signal will be reduced. I like my input signal attached where the signal will be the strongest. Vise versa if you fade to the rear, but not sure who does that anymore.
Steve@Subthump is offline   Reply With Quote
Old 03-29-2014, 04:23 PM   #8
Bryan2230
Bryan2230's Avatar
So I just installed, having some problems. I swear it's sending all sound to the sub. Did I plug the wrong harness in? The beeping, saying door is open, is even going to the sub. And when it turns off, there is a pop.
Thank You,
Bryan
Old 03-29-2014, 04:25 PM   #9
Bryan2230
Bryan2230's Avatar
I have it going through front RCAs, but even if I fade it the music doesn't sound any better.
Thank You,
Bryan
Old 03-29-2014, 05:40 PM   #10
Steve@Subthump
Sounds like the settings are wrong. You need to set the low pass on the jbl amp around 80Hz or so. That will filter out the highs going to the sub. You can also elect not to use the remote on since the jbl has a sensing remote and that should eliminate any noise at shut-down.
Old 03-29-2014, 06:11 PM   #11
Bryan2230
Bryan2230's Avatar
Yeah, I had crossover way too much. Sorry, I haven't ever really dabbled with real amps before now. I installed factory sub in my 2010 Camaro. Got it in, sounds good. Thank you. Awesome product!
Thank You,
Bryan
Old 03-29-2014, 06:32 PM   #12
c5dreamer
Drives: Tacoma/2LTRS
any pictures?
c5dreamer is offline   Reply With Quote
Old 03-29-2014, 10:31 PM   #13
Bryan2230
Bryan2230's Avatar
I don't have any step by step pictures. I have a final product picture. I'll add later.
Thank You,
Bryan
Old 03-29-2014, 10:42 PM   #14
Bryan2230
Bryan2230's Avatar
Finished product! Sounds good now. I only have crossover at like 45-50Hz. I have very little gain, and bass at probably 8/12
Thank You,
Bryan
