Old 03-25-2014, 09:02 PM   #1
FanDamNCSU
Drives: 2010 CGM 2SS/RS - L99
Lowered with Irregularities
I lowered (Hotchkis 1" Lowering Springs) my 2010 Camaro SS a few months back, but just today as I was sliding some wooden ramps under my car I realized that one side was lower than another. I have put my car on the same ramps before (after lowering the car) and have not noticed this. So I broke out the tape ruler and measured the height of each fender of the car. This was done in my garage on level concrete, from floor to peak of fender well down the center of the wheel.
I came up with the following measurements:
Driver Front 28 - 1/4"
Passenger Front 28 - 3/4"
Driver Rear 29"
Passenger Rear 30"
Where should I be looking to try and get the car more even? When we installed the Hotchkis springs we followed the directions and made sure to index the springs correctly with the rubber spring isolator.
Could anything have caused the car to change height after the springs were installed?
Thanks for your input.
Performance:
Vararam CAI, Vmax Ported Throttle Body, GM Performance Dual Mode Exhaust (NPP), JRE Tune, Hotchkis TVS Stage 2 Track Pack, Vitesse Paddle Shifters, Vitesse Throttle Controller
Functional:
Hex Vents, Elite Catch Can, WeatherTech Digital Fit Mats, Escort Passport Max
Cosmetic:
Heritage Grill, GM Splash Guards, ZL1 Rockers
FanDamNCSU is offline   Reply With Quote
Old 03-25-2014, 09:10 PM   #2
tanur420
Drives: 2011 Camaro SS
Mine was like that when I first installed my bmr springs. But got it aligned and it evened out. Im not sure what I had out of whack
tanur420 is offline   Reply With Quote
Old 03-25-2014, 09:59 PM   #3
FanDamNCSU
Yeah, I've got everything aligned and wheels balanced as well. I just can't think of what else could cause that as I don't recall having such a difference up front when sliding the ramps underneath.
Any other ideas?
Performance:
Functional:
Cosmetic:
Old 03-26-2014, 08:49 AM   #4
Broke Pilot
Drives: '14 1SS 1LE,'68 Chevelle,'70 Vette
Sounds like your drivers rear spring isolator is crushed or possibly shifted? Odd that the drivers side is lower all together. I'd start looking at the drivers rear first since it's the lowest and the drivers front is off by 1/2"...
Overkill is underrated....
Broke Pilot is offline   Reply With Quote
Old 03-26-2014, 08:52 AM   #5
ClawSS
High-tech Redneck
ClawSS's Avatar
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8
Maybe you should start riding on the passenger side for a while.
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning.
ClawSS is offline   Reply With Quote
Old 03-26-2014, 09:19 AM   #6
SSICKO
SSICKO's Avatar
Drives: SSICKO
I installed hotchkis springs two weekends ago and car sits at 28 1/2 both fronts and 29 1/16 at both rears... Before alignment the passenger side rear was 29 5/8. Thankfully they leveled out after alignment
Slowhawk Performance Built & Tuned
SSICKO is offline   Reply With Quote
Old 03-26-2014, 07:58 PM   #7
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Did you time the bushings? That could be holding things up to an extent.
Best regards,
Tyler
888-308-6007
Old 03-30-2014, 09:37 AM   #8
FanDamNCSU
Well I discovered one problem. Looking at each strut assembly, I discovered that the passenger rear spring has shifted off of the top isolator. I'm not exactly sure how this occurred as I was present and helped with the installation and we had double-checked the positioning of the springs on the strut assembly. Additionally, with that being said I haven't hit any potholes or anything that would cause it to shift.
I'm going to pull the strut and reinstall the spring and replace the isolators soon. Hopefully that will balance things out. We never did time the bushings, so I'll look into doing that as well.
Thanks for the heads up and all of the tips, it's much appreciated.
Performance:
Functional:
Cosmetic:
