Old 03-26-2014, 01:21 AM   #1
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
car pulling to the right after lowering
So I really did not marked the camber bolts or anything.. I installed everything. I am using BMR 1.2" springs. Took the car for a right and its pulling bad to the right. My steering wheel turns to the right as well. And I have to correct to the left to keep the car straight.. did I do something wrong? I redo the left side trying to set spindle bolts to the marks from stock.. have not driven yet. Will have the car aligned Thursday.. will the alignment fixed my problems.. I had perfect alignment prior to springs.
Wuiquen is offline   Reply With Quote
Old 03-26-2014, 01:24 AM   #2
DemonZL1
199
DemonZL1's Avatar
Drives: like a granny
You need an alignment. Just didn't set the strut back where it needs to be. That gets sorted during the alignment...
2024 Silverado ZR2 LZ0 Duramax
2021 Shock SS 1LE A10
www.youtube.com/@demonworksmotorsports
Anderson composites coupon code : Demon
DemonZL1 is offline   Reply With Quote
Old 03-26-2014, 02:32 AM   #3
Bo White
Bo White's Avatar
Yep. Always do an alignment when you lower.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 03-26-2014, 08:21 AM   #4
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
You had to removed and then reinstalled the two bolts that are used to hold the front strut and also adjust camber. You also lowered the car which changed the toe.
You Must get an alignment to correct it.
A for effort. C- for not researching and understanding what you were doing...
-Matt
Old 04-04-2014, 07:01 PM   #5
Wuiquen
Wuiquen's Avatar
So alignment is done. car feels better but idk for sure yet cuz it was reaining so hard that I figured any impression could not be the best of it since the road and tires were all wet and slippery.
So what does the alignment specs mean? im suspension retarded
Old 04-04-2014, 10:33 PM   #6
Bo White
Bo White's Avatar
They done a good job. The main reason why it was pulling before is because the left front tire was -.85* camber and the right front had +.19* This is were both tires were leaning towards the right and can cause it to drift to the right going down the road.
Totalled:
Old 04-04-2014, 10:37 PM   #7
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Yup. Looks like you got your money's worth out of that alignment. Should handle great now!
shibbs is offline   Reply With Quote
Old 04-05-2014, 11:48 AM   #8
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
When installed my coil-overs(40mm drop), I flat bedded the car to the alignment shop because I knew the alignment would be way off(big time tire wear when driven). A non factory AKA sport alignment will wake up the car!
rockrau is offline   Reply With Quote
Old 04-06-2014, 05:10 PM   #9
Wuiquen
Wuiquen's Avatar
Thanks guys. I am glad I waited for this guy to do my alignment. He said he's worked on corvettes and hot rods. He was pretty cool too. I think the car feels better and handles better there is some pull to either side if I let go off the steering wheel for a while but I think that's cus of the roads and imperfections. Otherwise I think its great.
Old 04-14-2014, 10:34 PM   #10
Wuiquen
Wuiquen's Avatar
So after driving a little I think my car still needs alignment. Idk if its me that nmore aware of the road and steering or the alignment is off or the result of lowering the car that makes the car feel the road more.. It is like I have to make smaller adjustment on the steering wheel to keep the car straight at moments. But it doesn't pull badly. It is like if the road makes the car go and because of the springs
Sent from my XT1080 using Tapatalk
Old 04-15-2014, 07:45 AM   #11
HerRide
HerRide's Avatar
Drives: '14 2SS/RS AGM
^Huh?
Is it pulling to one side still?
I just got mine lowered and aligned and it doesn't pull but my steering wheel is very slightly off position when I'm going straight and it's making me nuts.
HerRide is offline   Reply With Quote
Old 04-15-2014, 08:34 AM   #12
Dropspeed
Dropspeed's Avatar
Search for Trammling online and read some of the posts...
Here is one example:
http://www.supraforums.com/forum/sho...-and-Trammling
Old 04-15-2014, 11:22 AM   #13
Wuiquen
Wuiquen's Avatar
Originally Posted by HerRide View Post
^Huh?
Sorry I rushed to type that. But yeah its the same for me. Sometimes I try to level the Camaro writing on the steering wheel and it like it won't go straight and have to keep it slightly off position as u mentioned. Other times is all good. I need to go on a freeway and see what happens
Old 04-15-2014, 08:28 PM   #14
Twoblindsheep
[COTW 1/6/14]
Twoblindsheep's Avatar
Drives: 2017 1LE
haha lowered mine and it was fine but did it on the stock RS wheels.. when it was warm enough i put on the ZL1 wheels and now i also pull to the right and the steering wheels is off too.. -_-
also i hope you are doing well lol thought i post a picture of how it looks now LOL
470rwhp!!
Twoblindsheep is offline   Reply With Quote
