Old 03-26-2014, 12:01 PM   #1
BenzinaBrera
BenzinaBrera's Avatar
Drives: Alfa Romeo Brera V6
Cams in LLT
Hi Guys, so im looking at upgrading my LLT heads with the bigger LFX intake valves but i also want to do cams, unfortunately due to my Crap country currency ZAR, i can never afford The Mace camshaft, but i did find out the LFX has increased duration and also is something i can afford! lol so is it possible to fit the LFX cams in the LLT? and if not, why not?
Or should i get my cams reprofiled perhaps?
[/URL]
Alfa Romeo- Only passions, great passions can elevate the soul to great things
BenzinaBrera is offline   Reply With Quote
Old 03-26-2014, 12:54 PM   #2
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
Your Alfa has the same engine as the V6 camaros?
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 03-26-2014, 05:39 PM   #3
BenzinaBrera
Yes the alfa basically only has a 3.2 LLT but i bored it out and put in 3.6 internals so now its 3.6 LLT.
Apparently Fiat Group developed the LLT head for GM in exchange for their Alloytec global engine design, after the deal for Fiat Group to buy out GM fell through the floor GM has since redeveloped the LLT head into their own LFX we know today
But, i digress, now about those cams....
[/URL]
Old 03-26-2014, 07:28 PM   #4
jtbravo
jtbravo's Avatar
Drives: 2011 LS
Anyone one have the CAM journal measurements?
BBK Long Tube, HF Cat, RX ICE-Olator, RX OCC, C.A.I Intake, ADM Scoop,
ROTO-fab washer relocator, Hurst short throw, MagnaFlow Cat-Back, VMAX TB;
ENKEI RAIJIN 19x9.5; HANKOOK Ventus V12 evo2 275/35zr/19
Coming soon... HPtuner... I hope...
jtbravo is offline   Reply With Quote
Old 03-26-2014, 08:40 PM   #5
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
This applies only to the LFX, don't have any info on the LLT
Jason@JacFab is offline   Reply With Quote
Old 03-27-2014, 02:52 AM   #6
BenzinaBrera
Just had a look at the alfas technical data also and it suggests that the lift is the same, unfortunately i cant find the duration data but yes this supports the fact that only the duration is increased on the lfx cam, i read somewhere that the lfx oil gallery might be located at a different area but i dont know how true this can be.
[/URL]
Old 03-27-2014, 02:53 AM   #7
BenzinaBrera
and thanks for the informative spec sheet RacnJsn95!
[/URL]
Old 03-27-2014, 02:53 PM   #8
BenzinaBrera
according to my alfas technical specs its the same as on the sheet posted above
Cam Journal diameter: 26.936 - 26.960 mm
[/URL]
Old 03-27-2014, 03:00 PM   #9
RenegadeSS
RenegadeSS's Avatar
Drives: Camaro LLT
You might want to also look into the LFX pistons also, as they have a higher compression ratio that the LLT. LLT is 11.3 to 1, and the LFX is 11.5 to 1 comp ratio.
RenegadeSS is offline   Reply With Quote
Old 01-27-2015, 10:27 PM   #10
OfficiallyTook
OfficiallyTook's Avatar
Drives: 2010 LLT victory red
Bump what happen to this one, wanted to put lfx cams in the llt , but no show of any gains
OfficiallyTook is offline   Reply With Quote
