Old 03-26-2014, 04:15 PM   #1
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
HELP! Battery dead need to get in the trunk
Need some help please.2103 ZL1 battery is dead need to get into the trunk fast. Also key will not come out of ignition. Thought I read a thread where there is a button on the bottom of the column to push but not one. Someone answer sap.. Thanks
Bigtime53 is offline   Reply With Quote
Old 03-26-2014, 04:19 PM   #2
Cat988h
Cat988h's Avatar
Drives: Rally yellow 2011 Camaro 1SSRS
I have an SS and I can get into the trunk through the back seat. Pull the back rest forward and you can get to the trunk. Then pull the latch on the underside of the trunk to pop it open.
ATI Super Damper, Katech C5R Chain, Jannetty 470 Comp Cam, Comp Valve Springs, Mellings Oil Pump, Manley Push Rods, Comp Tringion Upgrade, Cold Air Inductions Intake, 1-7/8 American Racing Headers w Cats, MBRP 3 Inch Exhaust, RX Catch Can, Eaton Tru Trac, 3.91 OEM, DSS Drive And Half Shafts, LPW Diff Cover,3 Inch Noweeds, Amsoil Z-Rod, Tuned by Jannetty Racing
Cat988h is offline   Reply With Quote
Old 03-26-2014, 04:27 PM   #3
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
OK which side is it on? This is my husband's car and he let me drive it today and I left the damn key on I guess. I am trying to get someone to come and give me a jump to start it. WIll the key come out once it is started? He is going to be pissed!!
Old 03-26-2014, 04:28 PM   #4
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
Try turning the steering wheel back and forth. Steering lock might be putting pressure on the cylinder. And yes....through the back seat
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 03-26-2014, 04:29 PM   #5
rebelyell22
There is a strap on the top of the back seat. http://static.ed.edmunds-media.com/u...mb-717x548.jpg
Old 03-26-2014, 04:35 PM   #6
rebelyell22
http://www.camaro5.com/forums/showpo...2&postcount=13
Old 03-26-2014, 04:35 PM   #7
HDRDTD
there are battery posts under the hood you should be able to connect the jumper cables to, to start the car. no need to do it from the trunk.
Old 03-26-2014, 04:37 PM   #8
AZ-ZL1
Dry Heat My @ss
AZ-ZL1's Avatar
Drives: 2012 ZL1 SUMMIT WHITE
Dont tell Dad...LOL
2012 #1765: Xpel Clear Bra, 15% Tint, M2W, LPE GT9 Cam, Ported Heads & Snout, Upgraded Valve Train, 90mm TB, LPE Dual Fan HX, 2.55 Upper, 9.1 Lower (18%), Id850's, KB BAP, Roto-fab CAI, AR Stainless Headers, 673 rwhp, A6, Nothin but Fun!
AZ-ZL1 is offline   Reply With Quote
Old 03-26-2014, 04:39 PM   #9
Stittville Ed
Stittville Ed's Avatar
Drives: 2012 Camaro
The key will not come out when the battery is dead.
Don't force it and break it off :-)
Stittville Ed is offline   Reply With Quote
Old 03-26-2014, 04:40 PM   #10
Maiv
Drives: 2014 Camaro 1LS
Is the car in park?
Maiv is offline   Reply With Quote
Old 03-26-2014, 04:46 PM   #11
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
Yes it is in park and yes we have tryed to turn the steering wheel. That is not what the problem is. The auto wrecker is here. Where under the hood is the battery post to give me a jump? I will not let him touch it till someone tells me., It is raining hard here now.Please help thank you
Old 03-26-2014, 04:48 PM   #12
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
It's a big red cap on the right side of the engine with a "+" on it.
shibbs is offline   Reply With Quote
Old 03-26-2014, 04:48 PM   #13
rebelyell22
It's on the right side with a red + cap over it. There is a small post by the airbox for ground
Old 03-26-2014, 04:49 PM   #14
rebelyell22
http://www.camaro5.com/forums/attach...8&d=1265093398
