Old 03-26-2014, 05:47 PM   #1
StreetOutlawLS3
StreetOutlawLS3's Avatar
Drives: 2013 Camaro SS LS3
Pfadt stage 3 suspension kit with 10.5 in rims all the way around
Okay guys here's the deal I have a 2013 camaro ss I have 20x10.5 (all the way around)(275/40's in the front and 315/35's in the back) I was wanting to do the pfadt stage 3 suspension kit but I noticed it comes with 1.25 lowering springs will this work with my rim and tire combo? Btw I noticed if I try to do a hard sharp turn it will rub a little bit is there anyway I can install the whole kit and just not install the springs?
StreetOutlawLS3 is offline   Reply With Quote
Old 03-26-2014, 06:02 PM   #2
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
If you rub now, you will definitely rub when lowered.
Yes, you can install the entire kit without the springs. Many people have bought the full kit, then sold the springs because they either don't want to lower it or because they already have something done (other springs, coilovers, air-ride, etc).
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 03-26-2014, 06:15 PM   #3
Synner
Drives: cars
Where is it rubbing on what wheels? Your offsets aren't right.
Old 03-26-2014, 07:09 PM   #4
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
If you are rubbing now, it would definitely rub more if lowered.
You could definitely install that package without the springs and be just fine, but the problem is getting your hands on that kit as Pfadt has closed their doors. Unless you can find someone who has left over parts (very unlikely) you will have to find an alternate solution.
Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 03-27-2014, 06:09 PM   #5
StreetOutlawLS3
I think it rubs right there on the top fender well I'm not 100% sure I've only heard it rub like 2 times and that's when I was trying to do a donut and the other time when I was in a hard sharp turn
Old 03-27-2014, 09:16 PM   #6
Synner
Drives: cars
Apply masking tape all around your wheel well and then do some lock to lock turns in a parking lot then look at the tape for marks. Do you know your offset? I have a giant tire compared to yours up front with no rubbing but its a custom offset.
Old 03-28-2014, 04:47 PM   #7
StreetOutlawLS3
I have a +35 offset a lot of guys on here are running these niche apex wheels with the same offset
Old 03-29-2014, 01:00 AM   #8
alaskacamaro
alaskacamaro's Avatar
Drives: 2012 2SS 45TH Anniversary
I have that kit installed with 10.5 wheels in back (315's). Fronts are 9" (275). No rubbing issues in tight turns except in the back if I hit a low spot in the road at moderate speeds. Of course my rear offsets are too low +23.
Even with the correct front offset (+23 or +35) your going to rub with a 10.5 inch wheel.
alaskacamaro is offline   Reply With Quote
Old 03-31-2014, 12:46 PM   #9
JDP Sales
JDP Sales's Avatar
You'll have to figure out where you are rubbing. Having a +35 up front may just be a matter of adding a small spacer to clear.
Best regards,
Tyler
888-308-6007
