Old 03-28-2014, 09:01 AM   #1
Billetmaster
Drives: 2011 SGM 2SS/RS
LS3 Downshift Throttle Delay
I was on the interstate last night, in the right lane, just cruising along (cruise control on) and minding my own business when an idiot in the left lane rolls up and then basically just sits there with their front tire about where my door is. Mind you, I am rolling along at about 80 while this is going on. Eventually, we come up on a truck in my lane so I have to slow down. 70, then 65, then 60, and the person on my left does the same thing, getting slower to match my speed. I quickly tire of this and decide to shoot the gap, this is where my question begins. I clutch it, throw it into 3rd, pin the throttle, release the clutch. Mind you, I have had this car for 2 years and Mario Andretti doesn't have sh&* on me as a driver (I may be overstating here by just a fraction) and this all happened within a second or so.
THIS FREAKING CAR ABOUT THREW ME THROUGH THE WINDSHIELD!!!
The hesitation only lasted about half a second but it nearly required me to have the seat upholstery surgically removed from my anal cavity. Once it picked up the throttle, the wonderful LS3 did it's thing and I never saw those fools again.
So, what is up with that hesitation? Is this normal?
Billetmaster is offline   Reply With Quote
Old 03-28-2014, 09:14 AM   #2
HardrockSS
Drive Fast Take Chances
HardrockSS's Avatar
Drives: 2012 45th anniversary SS
was your traction control or stabilitrac on? That will cause hesitation
2012 45th Ls3 M6:ECS 1500, Custom Cam ,Alky Meth kit, Mcleod Rxt, MGW shifter,Pfadt Tri-y headers Solo Mach X, 20%tint,3.91 gears ,Suspension upgrades, G-force axles.700 RWHP
http://www.slowhawkperformance.com/
HardrockSS is offline   Reply With Quote
Old 03-28-2014, 09:21 AM   #3
Billetmaster
Yes. I rarely turn them off.
Old 03-28-2014, 09:23 AM   #4
HardrockSS
HardrockSS's Avatar
That's your answer then, the engine will rob you of that power because it thinks the wheels are going to spin. That's why unless it's raining I shut off all nannies!
Old 03-28-2014, 09:35 AM   #5
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
I switched out my stock TB with a V-MAXX ported TB last summer, easy mod, and made a noticeable difference in throttle response. maybe something to look into.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 03-28-2014, 11:19 AM   #6
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
The engine does not rob power in anticipation of a loss of traction, it takes power away as a result of a loss of traction. In my opinion, and no offense to you and your abilities Mr. Andretti, but I think when the clutch came out, the RPM of the engine was still at the approx. 2000 RPM that is 80 mph in 6th gear. For an instant, you had massive engine braking going on. That all changed when the RPM caught up to the necessary point for 80 MPH in 3rd gear. The traction control grab, even in response to tire spin, I do not think would have felt that drastic.
gajagfan is offline   Reply With Quote
Old 03-28-2014, 11:44 AM   #7
RWD ONLY
Drives: 2010 Camaro 2SS/RS
I agree with gajagfan^^ to not have the problem is to help your synchro's out and press the clutch in, get the engine rev'd up to 3000-3500, put it in 3rd and let out! Then romp on er and it and will be a lot smoother and easier on your synchro's
RWD ONLY is offline   Reply With Quote
Old 03-28-2014, 11:46 AM   #8
yowansavoie
yowansavoie's Avatar
Drives: 2010 Camaro 2ss/rs ls3
same thing happen to me i was going 45 mph and there where 2 18 wheeler in front of me so i down shit in 2 with traction control on and the engine just stop and i literally almost hit my head on the steering wheel then a second lather the ls3 just kick in yo but after that i fond out if you remove the traction control it wont happen it will go without a delay but when ever you will down shift it with tc on and it will hit a high rpm the engine will stop for a second
yowansavoie is offline   Reply With Quote
Old 03-28-2014, 12:04 PM   #9
Spartan01
Spartan01's Avatar
Oh, I see what you are talking about... yeah some quick heel-toe action is an easy fix.
Old 03-28-2014, 12:16 PM   #10
gajagfan
gajagfan's Avatar
Thats it! If you get used to rev matching on every down shift, it becomes second nature. To yowansavoie, I guess the traction control could respond to a wheel that loses traction by skidding as well as spinning, which may be what happens when the clutch comes out and there is massive engine braking due to no rev matching. Again, rev matching soles this all.
Old 03-28-2014, 12:24 PM   #11
Spartan01
Spartan01's Avatar
This is gonna sound like a shameless plug but, I switched out my stock pedals with SRP bolt on pedals, really improves heel-Toe action.
Old 03-28-2014, 12:40 PM   #12
kannon
kannon's Avatar
Drives: 2012 Camaro 2SS/RS/M6
Why would you heel-toe to pass someone? No braking needed. Just clutch in, rev match/shift, clutch out, POWER. No heel-toeing in this scenario.
Suck Squeeze Bang Blow
kannon is offline   Reply With Quote
Old 03-28-2014, 12:43 PM   #13
kannon
kannon's Avatar
Also, 6 to 3 downshifts are just about the most fun you can have in this car as long as you do it right. With the "nannies" off you can end up sideways and spinning on the freeway if you're not at the right engine speed and have TC off. Be careful
Old 03-28-2014, 01:12 PM   #14
Spartan01
Spartan01's Avatar
I meant it was like when you are cornering and Heel-Toe shift, nott that you should actually Heel-Toe it.
