![]() ![]() ![]() ![]() ![]() Drives: 2014 Blue Ray Met. Camaro 1SS Vert Join Date: Feb 2012
Brembo brake rebuild or not?
Ok. After having your Brembo brake calipers powder coated is it better to replace the boots or not even if the boots are brand new with never seeing any brake fluid yet and did not get damaged during removal?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: cars Join Date: May 2011
They'll be fine.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
What he said. If you will track though you might look into Racing Brakes replacement seals and boots they supposedly do better with heat than the stock Brembo parts.
Sent from my DROID RAZR HD using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
![]() ![]() ![]() ![]() ![]() Drives: '12 2LT Convertible Join Date: Mar 2012
When I had Mike powder coat mine I took the opportunity to rebuild them because I really had no idea of the history of the calipers.
New cross over tubes, bleed screws, pistons, seals and dust boots. Unfortunately I put them back together on install day and the new front caliper boots were the wrong size. So I ended up reusing the old ones after a good cleaning. If your old boots are not cracked or rock hard, I think you'll be fine. Do check out the kits from Racing Brake though. It's nice stuff.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
Ok. The ones who have took their brakes off to paint or powder coat did you reuse the copper washers and the caliper bolts or did you buy new replacement parts?
#6 |
New washers, same bolts.
#7 |
![]() Drives: 13' Black 2SS/RS Join Date: Dec 2013
You have to use new washers on the banjo bolts
#8 |
Ok. What about the bolts that hold the caliper to the steering knuckle? The ones that are torqued at 30 ft lbs plus 90°. I heard that stretches them and should be replaced. Just wondering who didn't and if that caused any problems?
#9 | |
I will look up what the bolts are. |
#10 |
Ok. Thank you
#11 |
The caliper bolts are TTY. Buy new ones. If I remember right they were less than $25 for all 8 at the dealer.
#12 |
Bolts are TTY
