Old 03-29-2014, 10:52 PM   #1
TheBandit18
TheBandit18's Avatar
Drives: 2011 Camaro 2ss M6
Tighting top strut nut after installing lowering springs
I was curious doing the install on my bmr split drop springs. how can i get the top nut tightened to spec i don't have an impact. I have it as tight as i can get it but it doesn't seem like enough. The second nut to mount the strut to the car is tight.
Any help?
TheBandit18 is offline   Reply With Quote
Old 03-30-2014, 05:59 PM   #2
Black 13 Maro
Drives: 13' Black 2SS/RS
Just put the torx to keep it from spinning and tighten as much as you can, that's what I did and have zero issues! You will be fine, it's better than going at it with an impact as that spins the struts shaft which I don't think is good.
Black 13 Maro is offline   Reply With Quote
