Old 03-31-2014, 12:29 PM   #1
rayers0423
rayers0423's Avatar
Drives: Camaro SS 1LE
burnout techniques
Looking forward to doing some runs in the near future. Obviously turning off traction control. But any pointers would be helpful.
rayers0423 is offline   Reply With Quote
Old 03-31-2014, 12:37 PM   #2
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
best suggestion I can give is invest in a line lock.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 03-31-2014, 02:59 PM   #3
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
Sell me your F1's for super cheap and put cheap tires on for the burnouts.
cornerspeed92 is offline   Reply With Quote
Old 03-31-2014, 03:26 PM   #4
TxBandit911
Call Me"Doc"
TxBandit911's Avatar
Drives: 2014 2SS/RS 1LE BLACK
Best advise ever. Not crazy $$$, and definitely worth it.
TxBandit911 is offline   Reply With Quote
Old 03-31-2014, 03:29 PM   #5
YUHATIN
Drives: 2013 BLACK 2SS/RS LS3
WHATS A LINE LOCK?
YUHATIN is offline   Reply With Quote
Old 03-31-2014, 03:32 PM   #6
jvoisel
Drives: 2010 2SS/RS M6
Originally Posted by YUHATIN View Post
WHATS A LINE LOCK?
A line lock is a device that allows the front brakes to lock independently of the rear brakes via a switch. This way you can lock the front brakes, and do a burnout without the car moving.
2010 2SS/RS
jvoisel is offline   Reply With Quote
Old 03-31-2014, 04:14 PM   #7
Col. Brain
Drives: 2012 Ram 1980 Malibu
http://www.summitracing.com/parts/sum-760002/overview/
They are cheap
They lock the front brakes while you heat up the rears
Can do it with a button or switch. Plenty out there.
Col. Brain is offline   Reply With Quote
Old 04-01-2014, 03:44 AM   #8
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
I don't burn rubber in the 1LE. Too much wheel hop and guys on this forum have had their half shafts snap.
2013 1LE NPP GBE
Mods
Track Days
CrystalRedTintcoat is offline   Reply With Quote
Old 04-02-2014, 04:35 PM   #9
YUHATIN
Old 04-02-2014, 05:20 PM   #10
trashmanssd
trashmanssd's Avatar
Drives: Black 14 2SS/1LE/RS 14 Tundra
Hell I cant even get into the throttle real hard in second gear yet not warm enough here cant get enough heat into the tires. just over comes the rear wheels and start to get hop.
trashmanssd is offline   Reply With Quote
Old 04-02-2014, 08:29 PM   #11
alv927
alv927's Avatar
Drives: 2013 camaro 2ss/rs dusk edition
pop the clutch stay on the gas and hold the brake with your left foot.( clutch then brake kind of fast) OR like my friend did on my car he held the brake with his right heal and worked the gas with his right foot (front tip) "heal brake toes gas" while holding the brake with his left foot. Either way works good.
alv927 is offline   Reply With Quote
Old 04-03-2014, 11:50 AM   #12
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
Line lock is a good idea. Never do water burn outs with tires with tread as the water picked up in the tread will pool at the bottom of the tire and kill the launch. I would not assume that a burnout to heat a street tire will help its launch. If you really want to launch this car hard, get some drag tires or slicks for when at the track. They are much cheaper than the Goodyears anyway!
PS: Just keep in mind that the addition of traction can help find the next weakest link.....and that can be costly!
gajagfan is offline   Reply With Quote
Old 04-03-2014, 12:07 PM   #13
Todd in Vancouver
Todd in Vancouver's Avatar
Drives: 2014 ZL1
Being a fairly new ZL1 owner I find burn outs available at almost any point I desire and sometimes even when I don't. LOL
Todd in Vancouver
'14 ZL1 Camaro
'67 Camaro SS Pro-tour in process
How hard can it be...
Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession
Todd in Vancouver is offline   Reply With Quote
Old 04-03-2014, 12:46 PM   #14
1LE Captain
1LE Captain's Avatar
Drives: 2014 Red Rock 2SS 1LE RS NPP
Use the launch control, you will take off but you can lay serious rubber if you want.
1LE Captain is offline   Reply With Quote
