![]() Drives: 2012 Camaro 1ls Join Date: Aug 2012
2012 V6 Suspension Steering Loose
Just upgraded to ss 20" wheels and now the suspension and steering are feeling loose. It kinda floats side to side over bumps and changing lanes. The car was aligned directly after the wheels were installed. It is not that I do not know how wider tires feel. I own a 1le as well. The v6 is my daily driver.
What is the best way to correct this feeling on the V6? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Sway bars?
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
could it be that going from 18s to 20s I need to have an ss alignment and not the v6 alignment?
![]() Drives: 2010 2SS Black/IOM Join Date: Sep 2013
Similar to this, I just installed the BMR 1" drop for my SS. Had it aligned the next day but sometimes the steering feels loose or I get the floating sensation going through turns/bumps. Is the sway bar to blame?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
Radius arm inserts really sharpened up the steering for me. See here-
http://www.camaro5.com/forums/showthread.php?t=365423 Also worn struts usually get "floaty" and would be worsened by heavier wheels and tires. |
#6 |
![]() Drives: 2013 camaro ls; 2005 rx8 Join Date: Mar 2013
Im getting the same feeling...but ive had my springs and sways and a bunch of other suspension parts already upgraded...so i had a feeling it may be the struts giving way...is there any way to test these without removing? I plan to upgrade them just wasnt in budget for awhile..lol
#7 |
Leaking oil is always a dead give away. But the classic test is just to stand at each corner and push down and then let the spring rebound and repeat until you set up a good rocking motion.
Then stop. If the dampers are doing their job, the motion of the chasis should cease on the next rise.
| Tags |
| steering, suspension |
