Old 03-31-2014, 09:50 PM   #1
my2SSRS
Drives: 2015 ZL1, M6, Crystal red
Exclamation HELP!! FOOSE wheels wont balance!!!
Got my Foose outkast rims about a month ago, had them mounted up and balanced, only static balanced...put them on and took off, about 35 mph all the sudden the wheel starts shakin like OMG!! bad, and its the whole car also....so I take them off and back to the shop, they spin them and there all off!! So I watch them redo them, and they zero out, take em home, put em on, and take off...same thing!! Tires have less than 5k miles on them, and I had ZERO shaking with the stock rims and these tires...so back to the same shop and the owner tells me to take them to another shop that has a Roadforce balancer, pick em up a couple hours later and the guy tells me that i'll probably still have a shake, says the wheels are HEAVY...and sure enough still have the shake...starts around 35, goes away around 70 them comes back after that. Called West Coast Camaro, and they don't think it could be 4 rims bad, but they cant spin up just rims to see if there out?? I asked about having them dynamic balancing them, they said it would just be to much weight on them and probably still shake....I was gonna have a friend bring his Camaro over and put one at a time on his to see if they all shake or I can narrow it down. Wondering if anyone has had any issues with these or any other after market wheel and what they did to fix it, don't really want to send them back....thank for any info...
my2SSRS is offline   Reply With Quote
Old 04-01-2014, 03:17 PM   #2
CamaroKid300
ace5.org
CamaroKid300's Avatar
Drives: 2017 ZL1 M6
I know you don't want to, but I would send those suckers back so fast.
Good luck.
Stock...For Now.
CamaroKid300 is offline   Reply With Quote
Old 04-01-2014, 08:08 PM   #3
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
No reason you can't dynamically balance those wheels. I've balanced Hummer H2 wheels and they were fine. Are the wheels hub centric? if not, do you have the hub rings installed? Sounds like the wheel might not be centered on the hub perfectly.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 04-01-2014, 09:14 PM   #4
Synner
Drives: cars
Either spin the tire 180 degrees and try again or send the wheels back if they're that bad.
Old 04-01-2014, 09:32 PM   #5
my2SSRS
yes they are hub centric, and the wheel face's are true...the reason i dont want to dynamic balance them is i really dont want to see the weights right inside the spokes...but that mite be the next thing i try...thanks..
Old 04-01-2014, 11:09 PM   #6
Visago
Visago's Avatar
Drives: 2010 Camaro 2SS/RS
That sucks...very surprising with a product from Foose. Good luck.
Visago is offline   Reply With Quote
Old 04-01-2014, 11:16 PM   #7
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
are you saying you only have weight on the back side and not the front? If so, yes you need to put weights on both sides (and yes you'll see the sticker weights). this is normal.
I've gotten away with weights on one side years ago on 15" corvette wheels... but it's obviously not working for you. there is no reason they shouldn't balance properly.
maddoggyusa is offline   Reply With Quote
Old 04-02-2014, 12:25 AM   #8
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
You must not be familiar with Foose wheels.
SUX2BU is offline   Reply With Quote
Old 04-04-2014, 11:39 AM   #9
HDRDTD
Don't forget to check for roundness as well. If you have a wheel or tire out of round, it won't matter if it's balanced.
Old 04-10-2014, 08:30 PM   #10
67motorcat
Blown Cool Breeze
67motorcat's Avatar
Drives: 2011 Black on Black 2SS M6
Plus 1....any wheels cast in China will be a hit or miss.
Some are great,some are complete crap.
Had a 2010 IBM 2SS M6
Enjoy life.Think of all the women on the Titanic who passed up dessert.
67motorcat is offline   Reply With Quote
Old 04-11-2014, 08:27 PM   #11
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
Could try some wheel balancing beads, I had one tire on my truck that had the same kind of issue and the beads helped. But I wouldn't use them for track use.
Life is too short to drive cars that suck.
My build Thread
mmarx82 is offline   Reply With Quote
Old 05-09-2014, 03:42 PM   #12
Alain
Alain's Avatar
Drives: 2016 Challenger Hellcat, 2018 ZL1LE
Any updates?
Alain is offline   Reply With Quote
Old 05-09-2014, 04:28 PM   #13
my2SSRS
So I ended up finding one wheel that would not static balance. Had it dynamic balanced and no problems at all! 145 and no shakes! Other than that they are awesome! Lots of compliments on them!..
Old 05-13-2016, 07:26 PM   #14
JusticePete
Drives: Camaro Justice
And people wonder why the only wheels we sell are made in the USA by Forgeline.
