Old 07-31-2009, 03:42 AM   #1
ss rs camaro
Drives: blk ss rs
RPMS
Can the dealer plug into the computer and tell how high the rpms were taken up to.
ss rs camaro is offline   Reply With Quote
Old 07-31-2009, 04:40 AM   #2
djsnoflake
Faith Keeper
djsnoflake's Avatar
Why what did you explode??
LOL I imagine they can probably tell. They gave me a print out on my old truck about how many times the govenor kicked in................
Old 07-31-2009, 08:03 AM   #3
SoloSK71
SoloSK71's Avatar
Drives: 2010 Camaro 2SS
There is a record kept that can be pulled in the even of an accident, but it is covered under (I think) privacy laws. It has speed, brake force, maybe a couple other things.
Someone with better search-fu than I might be able to find it.
- SK
- 2G1FT1EW9A9132212
- Life is hard when destiny believes in you.
- As coherent as a pit bull in a spin dryer. A dribbling tartan frothbucket.
- Good money, bad girls. How can life be any better?
- God saves. The devil invests.
- This may be the ultimate guide to problem solving.
Originally Posted by MontyCarlo View Post
it's not a WD-40 problem, so it's got to be a duct tape problem
SoloSK71 is offline   Reply With Quote
Old 07-31-2009, 08:04 AM   #4
fastball
Banned
Drives: 2017 Camaro 2SS 6MT
I doubt GM would be this anal about the warranty, but I know every time you bring a Porsche in to the dealer for an oil change they check to see if you've ever hit the rev limiter, and if you have they will void your warranty, even if there's nothing broken. They'll void it for future use.
Although, they print this in big, bold font in their owners manual, so you do know what you're getting yourself into.
fastball is offline   Reply With Quote
Old 07-31-2009, 03:31 PM   #5
MikeZ28
Drives: '04 GTO, '00 Z28, '95 Z28
Disclaimer: I don't know about the new Camaro. But on most GM cars, it would only store the RPM or other data if there is some kind of malfunction...for example it might store a "freeze frame" of data like speed, RPM, temperature at the time of the malfunction, but it would not set a code for just hitting the rev limiter a little bit. But then again if you miss a shift and the thing revs to 10,000 RPM, that might be severe enough to cause a code to be set.
MikeZ28 is offline   Reply With Quote
Old 07-31-2009, 03:40 PM   #6
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
So why don't set the rev limiter lower?
Old 07-31-2009, 03:45 PM   #7
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
Yes they can. As soon as you hit 6,500 rpm, the fuel pump shuts down. I've done it a few times already.
Hylton is offline   Reply With Quote
Old 07-31-2009, 03:49 PM   #8
Bbrock25
Bbrock25's Avatar
Drives: 2010 1SS/RS Inferno Orange
Why does the RPM go up to 9K? No not being a smartass just curious. Why didn't they just limit it to 6.5 or 7k ?
Bbrock25 is offline   Reply With Quote
Old 07-31-2009, 03:50 PM   #9
Hylton
Hylton's Avatar
This car has something called a BCM. It keeps track of everything the driver has done with the car (RPMs, top speed, idle time, etc).
Old 07-31-2009, 03:53 PM   #10
Hylton
Hylton's Avatar
Because you can tune the fuel cut-off to anywhere you want. I will be moving mine up the rpm range to take advantage of the hp the car has. You can even tune the fuel cut-off out if you want and then you can rev her till she blows.
Old 07-31-2009, 03:59 PM   #11
Bbrock25
Bbrock25's Avatar
Ah I see.
Old 07-31-2009, 04:38 PM   #12
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Top Speed? Uh oh........How fast do you have to be going before On Star does something...thats assuming if they do do something.
Old 07-31-2009, 04:49 PM   #13
Hylton
Hylton's Avatar
On Star won't do anything unless you report the car stolen. The information is just being stored, that's all.
Old 07-31-2009, 04:55 PM   #14
ss rs camaro
Drives: blk ss rs
Thanks for the info,I didnt blow up the car.I left the car with dealer to get repaint,for 10 days,25 days later i got the car back today, 125 miles more the car had on odometer Paint job not good .Told dealer to keep the car,took the plate off and left.The reason i ask the rpm question was to see if they beat on the car
Any other LS3 owners have a bad vibration sound at 1500 RPMs Johnyoder Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 18 07-23-2009 05:25 PM
ZZ Motorsports / Vector Motorsports - LS3 Build ZZcamaro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 06-22-2009 01:38 PM
Fbody Tranny help. GTAHVIT 4th Generation Camaros 9 11-10-2008 08:49 PM
Tuning the L99 Lifted07Sierra Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 09-02-2008 11:28 AM
