Old 04-02-2014, 07:49 PM   #1
Chevy_cowboy
Chevy_cowboy's Avatar
Drives: 2011 IOM 2SS/RS M6 Convertible
Door window weatherstrip... is this a common problem/TSB?
I tried searching for a thread about this but didn't have any luck. I noticed the outside weatherstrip trim on both doors of our car have places where the lip is pulled down, I tried gently pulling up on it with a plastic trim tool but I guess its been like that long enough that its kinda formed that way now, it just goes right back the next time you cycle the window.
Just wondering if this is a common issue, and is there a trick to fix it or should I see if the dealer will warranty it?
Heres the best picture I could get of the drivers door. Its got 2 places doing it, passenger door just has 1.
http://www.camaro5.com/forums/attach...1&d=1396482442
Thanks
Chevy_cowboy is offline   Reply With Quote
Old 04-02-2014, 11:03 PM   #2
angryv6
Lake Erie Monster
Drives: 02 Hyundai Santa Fe and 13 300
Yes it is.
angryv6 is offline   Reply With Quote
Old 04-04-2014, 04:34 AM   #3
HP_atTheWheels
HP_atTheWheels's Avatar
Drives: 06 Vette
My drivers side did that after I had the windows tinted, passenger side is good though. I have been looking around trying to figure it out to.
HP_atTheWheels is offline   Reply With Quote
Old 04-04-2014, 02:15 PM   #4
TooCool5
TooCool5's Avatar
I change both of mine ab out 4 yrs ago due to mold.
Easy to do, 1 forward screw they pop up and slide out under the mirror.
Old 04-04-2014, 05:27 PM   #5
Chevy_cowboy
Thanks, Is this what the online parts catalogs call the belt weatherstripping? Looking at the diagrams that seems to be the right part.
On 3rd gens I think they called them window sweeps, had to replace them on our 89 due to cracking and leaking water in the door.
Old 04-04-2014, 08:45 PM   #6
ChrisBlair
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3
Roll the window down. Then use your finger to fix it. Easy.
ChrisBlair is offline   Reply With Quote
Old 04-04-2014, 09:01 PM   #7
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Do the above, then leave the car in the sun with the windows rolled up. Once the weather gets warm, the rubber should straighten out.
My windows were like this when new, but eventually straightened out.
Rock-It Man is offline   Reply With Quote
Old 04-05-2014, 12:16 AM   #8
Chevy_cowboy
I tried prying it back up and leaving it for a couple days but next time i cycled the windows it was back. I think that would have worked if the original owner had noticed it and done that right away but now it's been deformed so long it might be permanent. I'll try it again on a hot day and see if that helps, if not I'll just replace them.
Old 04-07-2014, 04:39 PM   #9
ryzrs10
Drives: Victory Red 2012 2SS Auto
my dealer took care of mine on both sides of my 2012 2SS. fully covered under warranty.
ryzrs10 is offline   Reply With Quote
Old 05-07-2014, 11:16 PM   #10
Mando2776
Mando2776's Avatar
Drives: 2013 Camaro 2SS/RS
My 2013 had this issue on both doors when first purchased. I did use a thin plastic piece to pull them back up on a sunny day. It's been a couple weeks and so far they have straighten out. If it does happen again I will have dealer replace them.
Mando2776 is offline   Reply With Quote
